Setting better end points on servo >
Old 10-06-2011 | 06:44 AM
Default Setting better end points on servo
I had purchased this so i can set the end points a little further out to get more throw in steering.
Is it possible to make that adjustment.Someone who has used one may be able to advise.
RustyOne is offline
Old 10-06-2011 | 07:41 AM
Do think that will do what you are trying to achieve
That programmer will allow you to set a throw limit in the servo
It wont change the physical limit that your car hardware places on the servo travel
Cheers
crusey_aus is offline
Old 10-06-2011 | 07:51 AM
Toiffel's Avatar
Default Guide to Setting End points
http://www.twf8.ws/php/index.php?opt...=53&Itemid=169
Has some good info, yes I know it wasn't what you asked, but still useful....
Toiffel is offline
Old 10-06-2011 | 08:02 AM
Yes adding throw is one of the options in the software. It will let you go as far as just under 180 degrees on some servos IIRC. All this is assuming of course that the servo in question is a Hitec digital programmable.
TedMosby is offline
Old 10-06-2011 | 04:51 PM
Can you point out which part of the programing can i make that change.
RustyOne is offline
Old 10-06-2011 | 07:11 PM
Yeah, it's in the "resolution" setting. Default is "high", if you set it to "normal" it will increase the throw, then you can adjust the endpoints with the endpoint left and right slider. Again, this is assuming your particular servo will support this.
TedMosby is offline
Old 10-06-2011 | 07:47 PM
I'm using a hitec programmer on a hitec digital servo
RustyOne is offline
Old 10-06-2011 | 08:38 PM
Have used the programmer many times on planes to increase the trravel, have only used it to reduce the travel on surface vehicles. That way you get to make better use of the resolution of the radio on surface vehicles. What are you using it on that would need increased servo travel?
I can tell you this up front, read and understand the instructions before you start. It's not hard at all, but if you jump in not having a clue you will wind up with useless servo's if you don't know at least how to return them to factory settings.
bentgear is offline
Old 10-07-2011 | 06:46 AM
Ok that worked,thanks for the info.
Cheers
RustyOne is offline
Old 10-13-2011 | 07:16 AM
Cheers
ok since you found that what does dual rate do make it faster or what cause im lost with why you turn that all the way up?
imrob is offline
Old 10-13-2011 | 04:14 PM
I have the HPP 21+ and it's awesome to be able to center servos and set end points perfectly in the car with no radio. Plus I use the advanced features in my 79XX and 59XX servos. I also like the fact that it's a stand alone programmer and tester. It's a great tool that's worth every penny.
Steve. is offline
