-   -   calling all FUTABA 3PK users..... (https://www.rctech.net/forum/radio-electronics/53009-calling-all-futaba-3pk-users.html)
Integra 05-16-2011 03:22 PM
FS and FF. Im pretty sure if i remember correctly the FF only had the single antenna Vs the FS which has the Dual...I personally have Never had Heat issues and I run my Regulator Stood up Directly beside my Rx in a Sealed Box.
mellow 05-19-2011 01:25 AM
Just bought a 3pks. Part of the club now, should be here next week:sneaky:
some87 05-23-2011 11:04 PM
i just got a used 3pk and want to put a spektrum module in it but i remember seeing a while back that people were modding the antenna on the module so that it would be running in the same spot as the stock antenna. i looked through about 10 pages on this thread and didnt find anything at all about it. anybody have any links or a how to on how to do it?
jordan23junkee 05-24-2011 06:15 AM
Just to share with some who had bind with your R603fs Rx's then lost it, I had some debris in mine and now it binds after opening the Rx box and cleaning it out.......hope that helps some issues here......
PinoyCali 05-24-2011 11:16 AM
Throttle issue 3pks
Hello all
Pulled the trigger halfway the carb is wide open already.
Is there anyway i can adjust the trigger/throttle response?
some87 05-24-2011 01:09 PM
I think you can fix that with the EPA (end point adjustment)
jordan23junkee 05-24-2011 04:10 PM
What do you guys have for steering speed / steering return speed... ? I know for me If the Turn speed is too much the turn iisnt quite smooth...
some87 05-25-2011 11:06 AM
anybody?
AreCee 05-25-2011 01:54 PM
Originally Posted by some87 (Post 9164057)
anybody?
I have two 3PKs with Spektrum modules for over seven years and never felt the need to do the mod plus that mod prevents you from using any of the other modules.
If it's for looks, I have to be honest and say that I rarely ever look at my radio while racing.
mHOUPS 05-25-2011 02:00 PM
anybody?
Don't do it. It's for looks and the guys locally that have done it have had problems. If it's not done right, you pull the antenna wire out of the module...then you need to buy a new module.
some87 05-25-2011 02:18 PM
lol yeah thats true well ill just leave it then thanks guys.
Arboleda 06-09-2011 10:32 AM
Anyone able to comment on whether the newer R614FF receiver is compatible with a 3PKS/FASST transmitter? I saw someone allude to using them together a few pages back.
Integra 06-10-2011 06:26 AM
Not gonna happen.
VA_Racer 06-10-2011 07:42 AM
No they are not compatible.
8ightRider 06-21-2011 04:51 AM
My friend just picked up a RTR ve8 car which comes with a 3PK radio. It is advertised as a 3PK 2.4ghz and from what I can see has the module on the front of the radio for the 2.4 setup. Curious though what is the difference between the 3PKS and the 3PK if the 3PK has the 2.4 module installed?
Thanks!
