Hyperion 615 Duo3 problem >
Old 06-20-2011 | 05:02 PM
Default Hyperion 615 Duo3 problem
Hi,
Having a problem with my charger. On bay one it acts as expected, however on bay two... I can push no more than 4.9 amps.. ever.
Max ampreage I have pushed on channel one was 12 amps... I dont' know what is going on.
I have 2 8000mah batteries that I charge as a 10s and one bay one I'll pull 8 amps bay 2 4.9. Needless to say I never get a true sync balance charge.
any suggestions? Oh I'm on the latest firmware, and this has occured since I've had it (4.7)
Thanks!
ducatidesmo is offline
Old 06-20-2011 | 05:03 PM
Old 06-21-2011 | 05:47 AM
A shot in the dark perhaps, but make sure the power sharing is set to 50-50.
Dave H is offline
Old 06-21-2011 | 07:21 AM
Thanks Very much Dave!
I figured it out last night and it was set to 90 for channel 1
Can you only change that within the PC software?
I didn't see a provision where you could change it on the Charger.
Old 06-21-2011 | 02:08 PM
No PC needed, it can be changed in user setup, on channel 1.
Dave H is offline
