Need RX for Losi Controller >
Old 06-11-2011 | 09:32 AM
Default Need RX for Losi Controller
Just got a 2.4 GHz TX for my grandson's Rustler. We need an inexpensive compatible receiver. Wondering if the flysky receivers are compatible since they are less than $10. Not seeing a model number on controller but believe it is the one that is standard with Losi rtr's. Sticker says Losi Radio System w/ Spektrum 2.4 GHz DSM Technology. Thanks
Murray100 is offline
Old 06-11-2011 | 10:05 AM
You will need a Spektrum Reciever and they are not cheap
Cheers
crusey_aus is offline
Old 06-11-2011 | 01:25 PM
To elaborate on Crusey's reply: Spektrum air and ground systems are not compatable with each other. All the Spektrum compatable systems, (Flysky), that I know of are for air. It's a shame because I'm sure that a cheap Spektrum surface compatable reciever would sell like hotcakes... A used reciver will usually run 45-60 dollars.
blueridge72 is offline
Old 06-11-2011 | 01:41 PM
Either the Losi 2.4GHz RX or Spektrum SR300 cost $50 new and would work.
Actually any Spektrum DSM would work but not DSM2.
AreCee is offline
Old 06-11-2011 | 03:42 PM
trick25's Avatar
my advise is to go to hobbypartz and get a flysky gt2 if you want to stay 2.4 since the spec stuff is so expensive
trick25 is offline
