DX3R Help
Old 05-14-2011 | 03:04 PM
English365's Avatar
Default DX3R Help
The radio will bind up, but it will only turn right, and it glitches, and it also wont calibrate and everything has been set to 0. If you have had this or know anyway to fix it LMK! Thanks!
English365 is offline
Old 05-14-2011 | 03:15 PM
More info needed
What servo are you using and in what car ?
Is your servo mechanically centered correctly ?
What are your steering travel limits set at ?
What ESC are you using ?
Have you calibrated your transmitter to the ESC ?
Centre your throttle trim
Set throttle / brake travel (EPA's) at 100%
Calibrate ESC
Cheers
crusey_aus is offline
Old 05-14-2011 | 03:40 PM
Have you tried the Parameter Reset, including fully working the controls?
What does the Monitor screen show when you work the controls, does it follow the servo etc?
Dave H is offline
Old 05-14-2011 | 06:19 PM
English365's Avatar
First guy, I am using it with a savox 1258, tekin rs and yes the servo does have self centering
Yes I have also tryed the reset with no luck, seems as if after I do that it glitches more. I havent looked at the monitor will do that! Thanks for the elp and keep it coming!
Also it won't calibrate as well
Old 05-14-2011 | 09:17 PM
Yosh70's Avatar
What receiver? Almost sounds like you need a capacitor installed to aid your receiver in keeping the voltage up.
Yosh70 is offline
Old 05-14-2011 | 09:18 PM
English365's Avatar
micro, and I am using a spekky glitch buster
Old 05-14-2011 | 10:36 PM
Yosh70's Avatar
Well it shouldnt have a problem then....but just to eliminate all the possibilities try removing the glitch buster and see what happens. If not, try another receiver and let us know.
Yosh70 is offline
Old 05-15-2011 | 08:17 AM
cyoder#9's Avatar
I have a question . not to but in on your problem but I cant kind my book 4 my dx3r. if i want to slow down a servo i put positive expo?or what else can you do?
cyoder#9 is offline
