dx3s lipo
here is a pic of mine with one of my life packs 1600mah it will run for 8hr before it needs to be charged
Just wondering why you would bother running one of those instead of a set of LSD nimh's, such as Sanyo Eneloops
Do you get a better signal with the slightly higher voltage ?
How did you connect it into the radio ?
How much did it cost ?
Cheers
Cheers
if you look in the pic i wire in a plug and took out the battery tray
im builing a bigger pack that will even last longer for my dx3r pro
and life are lighter then lipo
so the lighter the radio the better when you run 45min main
