New Hitec Servos!!
Old 06-12-2011 | 07:08 AM
  #16
HSB-9360TH
Specs @ 7.4v Speed: 0.7 seconds@60° 229 oz.-in.
HSB-9370TH
Specs @ 7.4v Speed: 0.10 seconds@60° 319 oz.-in.
HSB-9380TH
Specs @ 7.4v Speed: 0.10 seconds@60° 486 oz.-in.
179.99 no way they can keep them for that much..
Graphite07 is offline
Old 06-13-2011 | 07:26 AM
  #17
Ambros303's Avatar
I'll probably get 2 and retire my Savox as backup. So far i've been really impressed by the 7950TH/7945TH and these new ones should be even better with lower power consumption to boot
Ambros303 is offline
Old 06-13-2011 | 07:32 AM
  #18
ntrain42's Avatar
Nothing new on the release date guys, still gonna be towards end of July.
Amros: The new ones will be a bit better,
But I doubt you will EVER see any performance improvements, especially if your running a 7950/7945 combo. I have 2-3 each of the 7950,7954,7945, and 7940's and these HV's already are in reality rediculous overkill. The only potential differences you may notice will in be how quiet they operate, and current draw/runtime assuming your running a nitro class. So if your rx pack is giving you say 40-45 minutes of runtime currently, you will probably notice that will be increased by 4-5 minutes if that matters to you.
ntrain42 is offline
Old 06-15-2011 | 09:25 AM
  #19
Ambros303's Avatar
Your right, the 79xx series is already very very good. Still want to replace my Savox with Hitec tho, so why not get the new ones and see what they are like first hand
I have to say tho, the Savox are very good, especially for the money but the Hitecs are just better quality and finish imo.
Old 06-15-2011 | 09:35 AM
  #20
10 Gauge's Avatar
Them there are some expensive servo's, mmmhmmmm. Damn they look nice though.
Still needing to upgrade the steering servo's on my LST but I think I am going to take ntrain's advice and stick with some less expensive 7955's or 7950's.
10 Gauge is offline
Old 06-15-2011 | 11:56 AM
  #21
rchoi's Avatar
Can I expect to see the price drop on 79xxhvs?
I need to buy 7940 but I am holding off with sf 50..
rchoi is offline
Old 06-17-2011 | 07:56 AM
  #22
ntrain42's Avatar
Doubtful since you can pick the 7940 up for around 120 shipped. The new BL servos are retailing for about 30 bucks more.
ntrain42 is offline
Old 06-17-2011 | 10:13 AM
  #23
rchoi's Avatar
I will give it a shot~
Did you know that Hitec is S Korea based company?
rchoi is offline
Old 06-18-2011 | 10:11 PM
  #24
lip
Im guessing Id need a BEC if I wanted to use a castle mamba max pro with these castle powered servos...Pity castle cant fix this problem with their esc
lip is offline
Old 06-18-2011 | 10:20 PM
  #25
rchoi's Avatar
Is there a 7.4v built in bec esc? MMP supports up to 7v
you also need high volt receiver
This means that you will be spending around 300 for servo, receiver, and ext bec
rchoi is offline
Old 06-20-2011 | 01:15 PM
  #26
specgie's Avatar
actually on the MMP's you can bump up the voltage to 7.4v-8.4v(like unregulated lipo) on the esc so that it provides 7.4-8.4 to your HV servo and receiver(assuming your RX and servo can take the lipo voltage). That way when you use your high-draw, high voltage servo and motor together the BEC voltage wont drop below the fail-safe or rx cutoff voltage (the many issues people are having with MMP/rx cut-outs).
specgie is offline
Old 06-28-2011 | 04:46 PM
  #27
rchoi's Avatar
wait...are you saying that MMP can be programed to supply 7.4 or above voltage to the receiver? wow... can you explain how to with this bump? i just ordered another external bec but i can cancel it if you teach me how to do it
thanks
Remy
rchoi is offline
Old 06-28-2011 | 05:49 PM
  #28
rider313's Avatar
Sounds like this is the servo to have in a losi 8ight. Can't wait for them to be released.
rider313 is offline
Old 06-29-2011 | 12:29 AM
  #29
teeforb's Avatar
Just being realistic guys, but it seems the savox servos are a better buy. I would say the specs are a tab bit better on the savox and at $95. Just curious, but what is the premise to buy the hitecs over the savox servos?
teeforb is offline
Old 06-29-2011 | 05:50 AM
  #30
ntrain42's Avatar
Savox servos IMO are junk. Few key things here:
A. Savox servos come nowhere near their "rated" performance specs(tested and proven locally with Hitec 6volt sport model servos outperforming Savox's 2 HV premium models). Under load Savox servos transit speed drops fast as well. Where Hitec servos are normally much closer to rated specs in real world applications as they are rated much more conservatively.
B. Savox servos are massive powerhogs drawing 2-3 times the amount of current compared to a Hitec HV counterpart.
C. The Savox warranty is pretty short/limited with a basic 1 year warranty compared to the 3 year no questions asked one provided by Hitec.
I can pick up a Hitec Premium HV 7954 for about 80-85 bucks shipped from TowerHobbies. Find me a Savox servo that will have 400oz of torque with .12 transit time at 7.4volts please, LOL! Not gonna happen.
If your gonna pay in the 80-120 range for a performance servo Hitec should be a first choice.
ntrain42 is offline
