HiTec High Voltage Servos..
Anyone had a chance to run the new HV servos from HiTec? I'm considering trying some of the lower priced ones for throttle.. Seems like a nice option to eleminate Volt reg and get full power to steering without paying $100 for 333oz servo..
Thoughts and ideas welcome..
A few people who run the digital "sport" HV servos 5495/5496 have had good results so far for the past few months using them for SC racing.
I'm thinking in the next month or so picking up 2 - 7954's and maybe 2 - 7940's.. Steering and throttle respectively.. But I was also considering the 5965 for throttle/brake.. What do you all thin about that?? At $55 it is sure tempting.. A bit slow at .14 @7.4 but it's about the same as what I am running now at 6.0v..
I have the 7945TH and its worth the money for sure, I just bought a 7955 and a 7940 used for an older 1/8 nitro buggy and stepped up to a 7.4V hump pack. a definate upgrade along with a 4PL with an extra Rx for my second car. The 7955 doesn't show 7.4V capable but by what I've read in forums it should be ok.
7955TG Titanium Gears
7945TH
7940TH
7954SH Steel Gears
7945TH
7940TH
7954SH Steel Gears
http://hitecrcd.com/blog/?cat=3
I'm sure you guys saw the other post but these are just BAD.
Those servo's will pay for themselves many times over when you find out they outlast a few of your rollers.
If you want to keep the price down instead of a 7954/7940 combo you could actually just do a pair of 7954's for both steering and throttle/brake. If your running at 7.4 volts, .12 transit time at 60 degrees is nothing to sneeze at and is quite fast. And you will never have to worry about brake fade, lol.
