ARE ALL STOCK BURSHLESS MOTORS THE SAME
I am looking to get a BRCA approved 13.5T motor. With that in mind I looked on the list, and but for the LRP Nosram they all look about the same - yes I know the speed passion v3 has different solder tabs - but I see little/no difference.
Are they the same or not?????????????????
if you are running blinky mode, you can probably find some speed but i run timing class so i have no idea how it works without adjusting the speedo.
All motors require slightly different setups.... gearing, timing etc..
And although they may perform similarly, I have found the Duo3 to run pretty cool. I would look for a motor with decent cooling holes in the can so you can really push some air into it.
In saying that the usual suspects seem to be The Duo2/3 motors and SpeedPassion V3...
I would stick with what others at your track run. Being able to share setup info is very helpful
Saying motors are the same is like saying all TCs are the same. They are built to the same set of rules but the end result will vary.
