Speed Passion Thread >
Like Tree4Likes
Old 06-01-2011 | 11:56 AM
  #241
Dave setup are on the SP site.....looking forward to post your 13.5 setup.
Solara is offline
Old 06-01-2011 | 06:11 PM
  #242
Originally Posted by Solara
All of our GT series ESC, the red/green blinking LED are located at the BOTTOM of the ESC circuit board. We have these ESC came out way beyond the no timing rule came out so we cannot relocate the whole design because of 1 rule (techically, it is not even a rule, it is a ROAR recommendation).
The GT series ESC should have a smoked color (1/2 clear) bottom case so the blinking red LED should be able to be seen from the bottom, or the side...
If you do have a solid black bottom case...your GT must be more then 2 years old.......I do have extra smoked color bottom case that I can send to you so you can replace the solid one...
One more thing...once you have updated to 508 no timing software, you must turn off the ESC, and recalibrate the radio in order to see the red blinking light....
Thanks. Mine does have the solid black bottom. I'll PM my address so you can send the smoked bottom.
RCMaster1 is offline
Old 06-05-2011 | 06:29 PM
  #243
I thought I should let everyone know that at my track a guy let me use his hobbywing lcd programmer to channge my gt2.1 pro stock to blinky mode and it worked. So I guess I am really running hobbywing?
mvieira342 is offline
Old 06-05-2011 | 07:06 PM
  #244
jnelson214's Avatar
I am getting ready to order my first speed passion esc and I was curious what program card i Need? I know the GT2.1 prostock works with either card but do I NEED to spend the extra $20 to get the better card? thanks
jnelson214 is offline
Old 06-05-2011 | 07:14 PM
  #245
All the GT2.0/2.1 series speedos come with the std. LED card. If you can spend the extra... get the LCD card. This will help you interface with a laptop/PC and you will be able to D/L the latest software from Speed Passion. Then be able to flash your speedo.
kwiksi is offline
Old 06-05-2011 | 08:40 PM
  #246
jnelson214's Avatar
excellent.. I wasnt worried about the $20.. it was mostly do I need it.. so I do and I will get it. Thanks again for the answer.
Old 06-06-2011 | 09:14 PM
  #247
jnelson214's Avatar
sorry to ask so many questions... are the cirtix motors 3000kv or 4000kv ok for a 4x4 buggy 1/10 I was looking at the combo sets and it comes with the silver arrow v2 or the GT2.0 LPF.. are these worth looking at or should I stick with looking at the GT2.1 prostock ? thanks again..
Old 06-06-2011 | 09:44 PM
  #248
Someone correct me if I'm wrong, but for 4wd mod buggy I believe you want the GT 2.0 Pro, and then download the latest version of mod software. The timing profiles for stock are really aggressive and aren't suited to motors under 10.5.
FWIW, I am running the GT 2.0 Pro in a DESC 410R and love it so far. Handles the power of my 4.5 550 motor easily, even in heat above 90deg. Just started selling off all of my old escs and will be converting everything to Speed Passion. Super smooth, great power, and excellent feel for both throttle and brakes. 2 thumbs up!
Jonny5 is offline
Old 06-06-2011 | 10:53 PM
  #249
ghoppa's Avatar
Default batteries in stock
Hey Solara,
any news on an ETA on more Speed Power
4500mah 30C 7.4V Racing Lipo batteries being in stock??
ghoppa is offline
Old 06-07-2011 | 03:21 AM
  #250
mjk1210's Avatar
Jonny5, great to hear you like the stuff. It is ok to use the stock software with mod motors if you turn the boost and timing way down. It is not "recommended" so that people dont fry their motors. I run the new 323 stock software with a 7.5 in mod buggy/truck/sct but have the settings real low. They work great.
The pro isnt required for a 4wd buggy but it isnt a bad idea to use one especially if running a lower turn motor closer to the limit of the speedo. with a 7.5 or 8.5 geared properly and cooled with a fan it should be fine. As always, check temps in new conditions.
mjk1210 is offline
Old 06-07-2011 | 07:08 AM
  #251
For 2S lipo racing....GT2 PRO ESC is the right ESC to use, over the Silver Arrow II version....we have most of our driver running the GT2 PRO along with the 3000 or 4000kv motor on Durango 410R and have a great result.
I will have that corrected on the web.....Silver Arrow 2 ESC is better used on 3S and 4S lipo powered racing.
Solara is offline
  #252
Thank you...you are correct on all points. And good luck with the upcoming event.
Solara is offline
Old 06-07-2011 | 07:12 AM
  #253
Originally Posted by ghoppa
Hey Solara,
I doubt it....it might be discontinued.
And reason why you are interested on this low mah and low c rating lipo..? May be I can find out they can get more of those instock...
Solara is offline
Old 06-07-2011 | 08:41 AM
  #254
It just depends. I have a HW programmer, but I have SP software loaded on it, so I'm actually running SP software.
cjtamu is offline
Old 06-07-2011 | 11:42 AM
  #255
discgolferlee's Avatar
just piccked up a speed passion gran turismo 2.0 LPF. hooked it up with a tekin 13.5t motor sensored. and I have NO brakes. radio settings have been rechecked and esc recalibrated over and over again and can't figure out what's up. It has very very faint brakes even with esc brake settings at 100%%%
anyone have any ideas.
help please hope i didnt waste my money on this esc
discgolferlee is offline
