2C rated charger's
Old 02-11-2011 | 04:27 PM
20 SMOKE's Avatar
Default 2C rated charger's
OK i have been doing this for a while and i know that the GFX and Turbo 35 can do a 2c charge but what else out there can,i don't keep up on what newer chargers do i have one the works and that was the end of it no need to keep looking.
20 SMOKE is offline
Old 02-11-2011 | 05:23 PM
Most chargers are capable of charging at higher rates
For a 5000mah pack
Entering 5 amps as the charge rate will charge it at 1c
Entering 10 amps as the charge rate will charge it at 2c
If it doesnt allow a charge rate to be entered then simply enter double the pack size
10000 mah for a 5000mah pack
Some will allow a capacity and a charge rate as multiples of 'c' to be entered
In most cases you will be limited to the maximum charging output of the unit
Most small, cheap chargers have a 50 watt limit
Charging a 3s 5000mah pack at 1c requires 63 watts
If charged on a 50 watt charger current will be limited to 3.9 amps (50 divided by 12.6), regardless of what you enter
I use an Icharger 206b which has a 6s / 20 amp limit (300 watts)
That means I can charge a 3s pack at 20 amps (4c if the pack is 5000mah)
If I were to charge a 6s pack I would be limited to 11.9 amps (300 divided by 25.2), which would be 2c for a 5000mah sized pack
Cheers
crusey_aus is offline
Old 02-11-2011 | 05:55 PM
You can find chargers with a 10 or 20amp max charge pretty easy. Beyond that, they start getting a little less common with either 30amps ot 40amps max charge rate. The 1420 charger is a 20amp charger. The new SuperDuo has 20amps in each port. The new TP dual charger also has 20amps max charge in each port.
There are several higher charge rate iChargers, the 106b and 1010b are 10amps, 206b and 208b are 20amp chargers, and the 306b and 3010b are 30amp chargers. FMA's Powerlab is the only 40amp charger that I'm aware of thats on the market. Prices run from $100 - 250. The iChargers are sold by AMain rebadged as Protek chargers, but they are the same.
There are several chinese chargers that have at least 10amps, GT Power A-6-10, HobbyKing EC06-10, and the Turnigy A-6-10 are 10amp, 200watt chargers. They have a 20amp 400watt charger, the Turnigy Mega charger with a 20amp charge and 400watts, but its reviews have been poor.
There are prob more.
Duster_360 is offline
Old 02-11-2011 | 06:54 PM
20 SMOKE's Avatar
For a 5000mah pack
Cheers
i did not ask for a explanation i know how it works i asked for the chargers
20 SMOKE is offline
Old 02-11-2011 | 06:55 PM
20 SMOKE's Avatar
thanks, the names are what i am looking for
20 SMOKE is offline
Old 02-11-2011 | 07:02 PM
If you knew how it worked you wouldnt have asked for a charger that does 2c
I was simply pointing out that any charger can charge at a higher rate, you dont need a specific charger with that function
Simply work out the rate you need and get a charger with a power output to suit
Tell us what size packs, what charge rate you need and what your budget is and you might get better advice
Cheers
Old 02-11-2011 | 07:31 PM
20 SMOKE's Avatar
Cheers
no they all dont,i have a multiplex that only does 1c
20 SMOKE is offline
Old 02-11-2011 | 08:06 PM
So if you have a 2000mah sized pack
You enter the size as 4000mah
Will it not be a 2c charge ?
Cheers
Old 02-11-2011 | 09:43 PM
You are looking for maximum charging amp of a charger rather than how many C it can put out.
To illustrate:
to charge a 5000mAh pack at 1C is 5A but 10A at 2C
to charge a 10,000mAh pack at 1C is 10A and 20A at 2C
If you know what's the maximum capacity pack you will be charging and at what C then you will know how many Amperage you will need, and select the charger that is capable of putting out the required Amperage.
Personally, I would aim for a minimum of 20A.
ganymede is offline
Old 02-12-2011 | 07:33 AM
In all the chargers I've had and used only the ICE, TC1030 and Hyperion chargers have limited the charge based on "C" which is a safety thing. I've never used an FMA charger, but I've read they either do the same thing or something similar. I have a BNIB Multiplex LN5014 charger , but I've never opened it.
Most chargers just ask for cell count (voltage) and a charge rate. I guess they assume you know what you're doing. The only safety check they make is on connected voltage versus the cell count you input. If you want to charge a 1C rated lipo at 5C (and have the max charge rate to do it), this type charger will not stop you.
Old 02-12-2011 | 09:09 AM
20 SMOKE's Avatar
I like the multiplex i don't like the low discharge rate 1amp for lipo,HKing has some descent one for a good price so i may look at them
20 SMOKE is offline
Old 02-12-2011 | 10:05 AM
You are able to set the charge current on the TC1030, I do it often usually 1.5C to get a faster charge during a race. However, the auxillary balancer has a recommended 3A limit though I have run up to 7A through it.
AreCee is offline
Old 02-12-2011 | 01:28 PM
HK has some decent chargers, especially for the price. I've been happy with the two I own. Look at the specs - HK is pretty good about giving both the charger output power and the discharge power limits in their specs. A charger with 5watts disch limit won't be able to do much in the way of disch even if the max discharge current is 5amps. You'll be quickly limited by the disch power limit. You need 50+watts of disch power to do serious disch for 2 - 3S lipos. Disch for higher cell count, will need more than that.
Sorry about the bad info on the TC1030 - I use mine mostly for NiMh, I only charge small 18th scale lipos with it. I have more capable chargers for my 3S and up higher capacity lipos.
Old 02-12-2011 | 01:59 PM
The bigger Hyperions, at least recent ones, have an adjustable C safety limit in the user setup. If I remember correctly it is set at 2C to begin with. When setting up a capacity it defaults the amps to 1C, but it can be changed and will stay there if you don't change capacity. Up to 5C is possible, without the fake capacity trick, well assuming enough power is available for the size lipo you are charging.
Dave H is offline
Old 02-12-2011 | 08:09 PM
I'm using a MuchMore Legend that can go up to 16A and an LRP Pulsar Touch good to 12. My packs are 6000 mah and charges full in about 40 minutes at 12A
mikeygar is offline
