Mamba Max set up
I recently purchased a mamba max used and could use some advice on setting it up.I have it programmed thru the castle link but not shure on setting up the throttle and break and everything elts thru the castle link..I read something about setting it up for my radio also..Im running it in a 1/16 revo and will be running mostly 2 cell lipo with 3 cell every now and then.Any advice would be appreciated.
What motor and batteries are you using ?
If you are using the stock motor and decent batteries these are the settings I use
Auto lipo mode
Lipo cutoff 3.4v / cell
Brake 60%
Start power high
Everything else default
Set your throttle and brake travel at 100% in the radio, then calibrate the ESC to set the endpoints
Cheers
Auto lipo mode
Brake 60%
Start power high
Cheers
