Tekin RS Pro problems >
Old 01-30-2011 | 06:49 AM
rcmark24's Avatar
Default Tekin RS Pro problems
Decided to switch over to Tekin and give them a shot. Hooked it up correctly, turned it on and the dreaded smoke puff. Capacitor was smoking hot. Yes I tried a different receiver, motor, sensor wire, battery is fully charged. Everything worked with the other speed control. Checked the wiring at least a million times just to be sure. Everything is right but the smoke!
rcmark24 is offline
Old 01-30-2011 | 08:53 AM
R/C Tech Elite Member
Just the cap that smoked ?-sounds like something was touching it shouldn't have- not saying-just saying. I got lucky once, wasnt watching , and solder the B+, B- backwards, and smoked the cap..That speedo still working for me today... Hope you get it figured out..
flame56mx is offline
Old 01-30-2011 | 11:29 AM
rcmark24's Avatar
Nothing touched. Even tried cutting the cap off to see if it would setup and no luck.
rcmark24 is offline
Old 01-30-2011 | 03:28 PM
Hmm, I would call Tekin, and get an RA#, their Customer Service is the one of the best--they will stand behind the product if its a bad speedo-which for an RS PRO-is not usually an issue--good luck, sorry to hear you had a problem..
Old 01-30-2011 | 04:01 PM
smokinu's Avatar
did you solder the cap on wrong?
The blue is NEGATIVE SIDE!
smokinu is offline
Old 01-30-2011 | 04:41 PM
rcmark24's Avatar
I know how the cap goes on. All wiring was correct.
rcmark24 is offline
Old 01-31-2011 | 03:00 PM
rangerjkb's Avatar
Contact Randy Pike on the Tekin RS/RS Pro ESC thread in the electric offraod section, he'll be sure to help you out.
rangerjkb is offline
Old 01-31-2011 | 03:08 PM
TY@TEAMTEKIN's Avatar
Team Tekin
Did you get an RA# for service yet? If not, let me know.
TY@TEAMTEKIN is offline
Old 01-31-2011 | 03:43 PM
SEEE-----now that's customer service-----
Old 01-31-2011 | 04:03 PM
DavidR's Avatar
Mark... If you're in a spot for the JConcepts race let me know... I've got at least 1 spare RS Pro this weekend you could use for the event.
DavidR is offline
