Gen Ace 5000mah 40c 7.4v lipo PROBLEMS hard case >
Old 09-04-2011, 08:40 PM
  #46
Originally Posted by Madulla
What kind of plug are you using? Maybe there is a bad connection at the plug. Does your charger sense it? Did you get a voltage off the balance plug? If not then yes the battery is toast, an internal problem. Atleast they have to 50C is stock for less than $40.
deans. its less than a month old. does this fall under warranty?
stnwag0n is offline
Old 09-05-2011, 05:08 PM
  #47
Panda-PR's Avatar
Having a problem with one of these lipos:
Was using two of them on my mugen eco, then I stopped for no particular reason and checked the voltage, one of the cells was at 5.08v !! and the other at 2.51v !!! WTH!! the other lipo was fine and the buggy didn't had any problems at all
Have no idea how did this happened
did I just lost my lipos??
Panda-PR is offline
Old 09-05-2011, 05:32 PM
  #48
Trader Rating: 32 (100%+)
It probably can't happen while in use.
gulio is offline
Old 09-06-2011, 07:55 AM
  #49
For clarification, are these failures the units with the bullet connectors integrated into the hard case?
I was looking at getting some inexpensive li-pos and noticed that they have 40C units with bullets integrated or pre-wired units...
Any difference?
cowboySiR is offline
Old 09-06-2011, 08:25 AM
  #50
Trader Rating: 67 (100%+)
The conversation was concerning the plugs that are inserted into the lipo batt, not hard wired. The plugs themselves are the problems. If you go back and look at the links to the ones to use and the ones not to use, you will see the difference. The ones that he says not to use are fluted (slotted) on the sides. When you push these in and pull them out of the lipo several times the slits (flutes) in the sides of the plug can flatten out and then the plug is loose in the batt when plugged in. I take a jewelers screwdriver with small blade and pry the slotted ribs back out when they start to collapse. Over time they will become too weak and must be replaced.
nutz4rcyktw is offline
Old 02-16-2012, 09:52 PM
  #51
MaplestreetRC's Avatar
I've had one of these for about a month and it's worked fine. This thread is scaring me though, I liked the first one so much I ordered 2 more. Hope I dont get burned. I'm also going to try the turnigy.
MaplestreetRC is offline
Old 02-18-2012, 02:00 AM
  #52
Iasis's Avatar
This thread seems like it only has anything to do with the versions that are not direct right? I have some that I bought about 2 weeks ago and they are completely awesome. Like so much punch my Savage pops a wheelie at 55mph awesome. I am getting some direct versions for the upcoming race season.
Iasis is offline
Old 02-18-2012, 02:14 AM
  #53
LOW ET's Avatar
Trader Rating: 109 (100%+)
http://www.youtube.com/watch?v=UClcOe8bmAA
LOW ET is offline
Old 04-18-2012, 12:07 PM
  #54
Default Gens Ace no good
Originally Posted by Raydee
Thanks for the vid link. I think I will go take my two packs apart and see if I can repair them.
Done that too ,but now not ROAR approved.
[QUOTE=rc's suck;9574487]Not what i wanted to hear. I just got a gen ace 4 cell today in the mail.
Originally Posted by rc's suck
I cut off the cheese plug and soldder a deans on my new 4s 5000 40c gen batt. Charged it up and ran with no problems. Happy with performance. Hope it will last
bat's with tubes or hard wired ?
Originally Posted by stnwag0n
my gens ace 2s 40c 5000mah battery died tonight. its not the kind that has the bullet plugs connectors. was driving my rustler and it just stopped moving. i tried the battery on another esc just to make sure it wasnt the esc on the rustler, but still no power. tried another battery and it powered right up. i sent a support request through their eticket process to hobbypartz, hope they can get this squared away. this battery less than a month old
The charge leads/plugs that came with mine were Deans rip-off's ,I used them to connect to ESC ,and they all failed (3).Replaced with Genuine Deans ,but batts were allready shot. 1 lead in particular had a dry joint at the Deans that i didnt pick-up ,the car would cut out ,and then go again ,i think it wes re-conecting intermitantly because of the heat generated ;eventualy picked it up while charging ,the charger would state "batt not connected" ,ide give the deans a squeeze and it would go ;I kept blaming the Deans ,would clean the contacts etc ,but the phenomenon persisted .
They were with tubes in my case .
Were paying upwards of $70.00 AU to $100 for these in 2s in OZ; not what ide call inexpensive .I blew 3 batts in 3 meetings .
Any difference?
+1 ,same question !
The plugs ;or the tubes ?
I tried this but no different ,batts were new,so were plugs.Cleaning the tubes helped a bit though .
Does anybody know if these faults been addressed by the manufacturer ?
noddy2 is offline
Old 04-18-2012, 01:32 PM
  #55
Default Gens Ace faulty
[QUOTE=noddy2;10621050]Done that too ,but now not ROAR approved.
+1 ,same question !
bump
noddy2 is offline
Old 04-20-2012, 10:44 AM
  #56
Questions?? Gens Ace Question Bump
+1 ,same question !
any thing new ?
noddy2 is offline
