ko mars owners, 2.4 hackers, step in
#76
Don't recall I don't think it matters I just asked the guy at the electronics part shop for a 12K resistor.
anyhow here is the module you need.
http://www.ebay.com/itm/Flysky-FS-TH...item3f26739b3d
#77
Hi,
So you mean i cannot use my gt2 module but get a module over ebay instead ?
If i want to use module form my gt2..is it possible ?
#78
#79
ooh...ok....thanks for your reply....
#80
I want to do this Mod to my Helios, but I don't think I will be keeping it. I need 3 channel capability with mixing, and the radio doesn't have it. I called Ko and asked if they could put a channel radio firmware on my radio, but they said no.. Does the Eurus have ppm out and the module is 2.4? hmmmmmmmm
#81
#82
Eurus has channel mixing, just wondering if it has the same setup as the helios.
I race Monster trucks (Clods) and the cheap radios don't offer some things I need. I am always looking for it to be the cheapest as possible, but I guess if I did anything with a new radio, I would get the Spektrum DX4S. A friend has one, and it has everything I am looking for..
#83
#84
I looked at those in the past. When it comes to a clod, and setting it up for racing, you need to have servo epa as high as possible. The Helios goes up to 150, most radios only do 120, that is a huge difference. Ill try and get the Eurus cheap somewhere, or make the move to DX4S..
#85
hi...I need advice...as someone selling this here in indonesia...so i don;t have to wait too long from ebay...
OrangeRX DSMX/DSM2 2.4Ghz Transmitter Module (JR/Turnigy compatible)
can this be use to mod my helios ??
really need help and advice..thanks a lot
#86
New questions about radio hack
There are about 5 different kit or module based 2.4 conversions for ppm output radios. I'm finding that there are some Spectrum modules that have turned up on Ebay. I have 2 Airtronics M8 modules that I would like to use on my KO EX1 radio. I can shove the module into the radio but have no response. Does anybody have the pinouts for the M8 verses the KO? I would love to be able to just swap 2 pins on the module and get it to work on my KO. Also, there is an orange dsmx and dsm2 module for futaba that comes with a receiver for under 50 dollars. Can that be converted to work on my KO? Thanks in advance.
#87
Wondering if this could work in a KO radio?
don't know if these 2 bind together or not?
http://www.hobbyking.com/hobbyking/s...strSearch=dsm2
to bind to there orange GR300 dsm2 land RX
http://www.hobbyking.com/hobbyking/s...dproduct=35061
#88
I don't think the module will work in the ko ground radio, the pins are in the corner, and the the ko are in the middle. I think this was for the air radios.
I would find a module case (empty) and put the FrSky diy kit in the there. Should fit from everything I have seen.
#89
Got a response from hobbyking the air and there surface receivers do not work together so there goes this idea!
#90
I just wanted to use the spectrum DSM2 hobbyking receivers I think that is a much better system than the flysky stuff.
