Airtronics Binding RX Help
I have the 92624 RX's and the 92524 RX's . I had an issue with my M11 and need to send it in for repairs and blew the dust off my M8 to use until it gets repaired from Airtronics. My issue is the 92524 rx bind up with no problem, but the 92624 will not. I am using the same method on the 624 that I used on the 524's that bound up fine. I cannot find the paperwork and have searched google on this with no luck.
This is what happens. I turn on the esc with the button held and it does not get into the flashing light mode to bind to the tx??? Its like I cannot get the rx to the programming mode. (the light on the rx flash for just a second, so I know its getting power.) I think that I have a sequence wrong here. PLEASE help!!!
I always put the radio in bind mode by holding the bind button and powering on the radio. Then I put the receiver in bind mode by holding the button on the receiver while turning on the esc, I hold the button until it starts to flash. This of course has to be done before the radio goes out of bind mode, (as I'm sure you are aware of). Good luck.
Still nothing, My issue is that when I hold the rx button down upon turning the esc on I cannot get the blue light to flash to go into programming mode. NO matter if the radio is in bind mode or not it will not flash to program.
I don't know what the M8 TX is or if its even adjustable you may be sol.
Anyways on the MT4 you can change from FHS2 to FHS 3 to FHS4 and you need to do that per the receiver type. Then when you select bind it will work. Otherwise it won't bind.
Again the M8 may be only FHS2 since its older so you may not be able to use it. Try going into the system menu in the M8 and see if go can change the FHS type.
Aaron
