Transponder repairs?
It's difficult but I've done it. If it's AMB, you gently slice around the end cap until it comes off. Then, you see if you can dig out the wire reminants. If you can, then just solder a replacement on, shrink wrap it, and then goop the cap back on. Inside the transponder is some sort of sealant so depending on where the wire broke, it might be tricky. Good luck!
