Icharger 106b+
Old 12-30-2010 | 10:41 AM
  #16
bigjayjay1's Avatar
Originally Posted by drewmugx5t
I got a balance board for it and it doesn't seem to want to work correctly. I plugged the board onto the 6S port and plugged the battery into the 2S port. When I go to charge it it says the balance port is not connected.
I just wanted to be able to extend the balance lead so I don't have the battery sitting so close to the charger. Am I doing something wrong or do I need something different?
That weird I use the protek board for MULTI balancing and charging option and it works perfectly. Maybe its the brand and how its wired.
bigjayjay1 is offline
Old 12-30-2010 | 10:42 AM
  #17
bigjayjay1's Avatar
Originally Posted by Duster_360
Don't know first hand, but this is an iCharger dealer and says it will work, mentions the 106b+ specifically -
http://epbuddy.com/index.php?main_pa...products_id=70
Email him and find out for sure.
Yup thats the one I have work fine no issues.
Old 12-31-2010 | 08:08 AM
  #18
simplechamp's Avatar
I'm just stupid and didn't use the most negative port. I thought you could use any of them, but apparently with just the single 2S pack you can't. Seems like at the time I would have tried all three, but must not have.
simplechamp is offline
Old 12-31-2010 | 09:21 AM
  #19
Not sure what you mean by most negative port?
Duster_360 is offline
Old 01-01-2011 | 07:01 AM
  #20
got main lead plugged in too?
gulio is offline
Old 01-01-2011 | 08:50 AM
  #21
There is 3 x 2s ports wired in series
If using a single pack you must use the one with the negative lead (right side)
The centre and left sockets will not work with a single pack
Cheers
crusey_aus is offline
Old 01-01-2011 | 09:12 AM
  #22
I know that, I have one and use it for single lipo (3010b), just curious what he meant.
