Swallow 2 Limits
Old 12-18-2010 | 02:30 PM
Sith Lord's Avatar
Default Swallow 2 Limits
I bought a Swallow charger some time ago at about the time I upgraded to Lipo. At the time my batteries were 3800mah so the swallow limit of 5A charging was fine.
Now with batteries being 5600, even 6000 and more for a standard hard 2 cell, does that mean the Swallow is no good and out of date? Do I need to either update my charger, of limit my new batteries to 5000mah?
Cheers
Sith Lord is offline
Old 12-18-2010 | 02:50 PM
I don't know if your charger is updatable or not. Even if it is, it's not likely a firmware update is going to increase its power or max charge rate. Thats usually goverened by the hardware inside teh charger and ratings of the various components.
There is nothing wrong with the charger as far as charging 5600 or 6000mah lipos. You are simply limited to 5amps and charging will just take a little longer.
You've basically outgrown the charger, especiall if your lipos are rated for higher than 1C charging and you'd like to take advantage of that.
Duster_360 is offline
