Novak Havoc Pro Cutting Out Problem
#16
I have been a long time Novak customer and currently run a Goat 3S/Ballistic in my crawler, GTX in one of my RC12s, another Ballistic in a different RC12, a Rooster in my old RC10 and this Havok Pro in my TC4. I will most likely replace this DUO2 with another Ballistic since they are the most popular at our club (and faster than my current setup ) I have always been happy with your products so if you ever need any combos tested, let me know if I can help. The offer stands on the DUO2 as well, just let me know if you need it.
#17
i wish i seen this post eariler. I was having the same problem with my havoc pro, but mine went up in smoke and now it's going in the trash. I was also wondering since i smoked my esc do you think the motor is still go? or should i replace it.
#18
Super Moderator
Trader Rating: 31 (100%+)
Send it to me and I'll get a new one from thier trade-in program motor should be ok but you never know, you'll have to try it. If it didn't get hot or let the majic smoke out it should be fine.
#19
Company Representative
TeamNovak Trade-In Program
Try your motor with a different esc. Hard to know if there is motor damage. Is the rotor in your motor fairly new? Weak/demagnetized rotor magnets can also be the cause of esc damage.
#20
thanks i guess i will trade it in for a new havoc pro sc. I would try the motor out on a new esc but i would hate to have another esc go up in smoke. Is there another way to check if the motor is still good..sorry but im pretty new to the hobby
#21
If you are planning to return your HP for replacement, you could include your motor and we can take a look at it for you. Be sure and fill out the form on the trade in page and write our tech guys a detailed note about your motor concerns and what you would like us to look for.
#22
thanks will do
#23
We are replacing all Havoc Pros with our much newer Havoc Pro SC controller:
#24
Super Moderator
are you looking to replace the 3s or the Pro?
they no longer make the version of the Havoc Pro that you have. If you send it in they will "replace" it with the new Havoc Pro SC w/X-Drive for $69. Would be worth every penny..imo
#25
opinion restrained...
normally i would post something here about many rc'ers experiences with Novak's esc's......Simply, the easiest way to fix a Novak problem is to replace with a Hobbywing, LRP or Tekin amongst others.
#26
#28
It's looking like that is going to be the future. Won't run castle cause they can't seem to make a bec into their esc's but would love to sell you a stand alone bec, hobbywing stuff is always sold out. Tekin and lrp, Orion stuff is just outrageous in prices though. But that's what I went to with the SCTE (rx8, pro4) cause the Novak system wouldn't cut it anymore. Would like to try viper stuff but they need to make a sensored system.
#29
I had the same issue with two of mine. Both times it was the sensorboard. You can use the built in hall effect sensor test to see if one of them is bad. Good luck.
I purchased a new havoc pro sc/8.5 motor/esc combo and a havoc pro sc by itself brand new from A main. Both worked fine, calibrated fine, everything seemed fine. About two packs in on the motor esc combo I started getting the locked rotor fault. So it went on the shelf until I could have it fixed. Then my other Havoc pro sc esc, with about two packs on it on a totally different motor, radio, chassis, battery etc. started having the rotor lock fault also. They didnt get run enough to even be dirty and are both DONE!! Im pretty dissapointed. My first time purchasing Novak by the way.
#30
Here is our current Trade-In program:
Trade-In Program
For technical assistance:
[email protected]
[email protected]
Trade-In Program
[email protected]
[email protected]
