XP SC450-BL Brushless ESC
Im new to rc world need help with this issue. I recently just purchase this new system to upgrade my sc10. When I turn on the power switch after turning on the the transmitter I have no power light on the esc, is this normal? I understand the first time I use this I have to calibrate the system. Whats the trick to this calibration with no power light? Seller says this was taken from new brushless t4.1. Thought I would try asking around here before sending this back.
thanks!
thanks!
Did the seller provide the manual? If not then head over to Team Associated's website and down load it. This would be my first step.
Thanks emag for the reply, that was the first thing I did was get a manual from TA. I think maybe the switch is bad just not sure. Gonna call TA when I get off work to see if they might have a solution before I send it back.
Hope you get it sorted out.
thanks!
thanks!
Did u sort it out? Cuase i have pretty much the same problem right now
