Power supply for Hyperion Duo >
Old 11-26-2010 | 07:26 PM
Default Power supply for Hyperion Duo
What would be a good power supply for the Duo charger?
fatcalves is offline
Old 11-26-2010 | 07:51 PM
Which DUO do you have? Do you want to run it at full power (some DUOs need 14.5+v to enable full power) which requires a diff power supply.
Duster_360 is offline
Old 11-26-2010 | 08:01 PM
Was looking at a 610 or 615
Old 11-27-2010 | 09:54 AM
This would run either, but wouldn't provide full power, but unless you're going to be charging unusual, this will work -
http://www.progressiverc.com/index.p...emart&Itemid=1
This one is hard to beat for the money unless you want to go with a PC server type power supply. Which wouldn't run the 615 at full power either due to the voltage.
Old 11-28-2010 | 06:34 PM
trerc's Avatar
I use a Rivergate Bulldog 30amp to power mine, its a tank!
trerc is offline
