Viper RC -
#1201
The first shipment of VTX10 and VTX10R's have arrived
We have sent nearly every unit out already, and haven't even filled all orders yet. So get your orders in, next shipment will be arriving Monday!
#1202
Definitely good news!
#1203
Those are some of the nicest looking ESC's I have ever seen.
My question, looking to get back into the hobby after a hiateous. I will be racing but not at a national level. JConcepts Supercup series(used to be Florida Electric series) mainly and club races. I am a nitro only guy, so this will be my first 1/10 EP venture, going 2wd buggy and SC not sure 2wd or 4wd yet. What motor and esc would you recommend. Will be running mod not stock.
Thanks in Advance,
Brandon
Thanks in Advance,
Brandon
#1204
got a xxx-sct and a viper 10.5 sitting on the shelf waiting for a 10r, any gearing suggestions for a medium size outdoor track?
#1205
Thanks in Advance,
Brandon
Thanks in Advance,
Brandon
Reuben Diaz
#1206
Brandon, The jconcepts supercup series is a great series. I TQ'd and Won the 2wd stock class when round 2 was at Mills pond using a vtx and the 17.5 motor. For 2wd I would use the vtx10 and any motor that you feel would fit your need. As for SC, It would depend on your choice of drive. For 2wd go with the vtx10 and for 4wd I would go with the vtx10r. The vtx10r will run a 550 motor.
Reuben Diaz
Reuben Diaz
You will have to look at what they run though.
Mod/13.5/17.5 can go either in buggy or 2wd sc
The 10r Will Handle a 550 in a 4x4 Just like any other sc esc out there.
Most robust and stable 10th speedo on the market now!
#1208
#1209
#1210
#1212
Are you Carrying anything Tq?
The boosted feture on the VTX series is nothing like tekin.. Took me a few tries to get it right no real motor problems though just dont go to much off the bat though! and Have fun racing.
#1213
When I was testing the VTX10/VST 10.5 boosted in my SC10 I was running 20/84. I believe the Losi internal ratio is about the same, so 20-21/84 should be a solid starting point. The VTX boost function creates massive rpm so often a lower gear can actually be faster and have more torque. I'd start 20/84.
#1215
4Likes
