Viper R/C Solutions - A New Line of Innovative Power systems!
#1429
I ran my setup for the 1st time last weekend and was getting pulled in the infield but was comparable on the stright.
78/54 43mm tires with a d3.5 and 12.5 rotor im +15 on timing on the can for 25* over all. I am thinking about going +25 and dropping the pinion to a 50* as i still had plenty of room to get more temp into the motor. I was coming off at 135* after 8 mins. The guys that were pulling me had more punch for sure and i can defiantly use a little more aggressive feel.
#1431
I think you're going in the right direction, your rollout is a little high. You'll probably find the D3.5 timed over 20 degrees just makes more heat, the sweet spot seems to be 15-18 degrees in my experience. When I ran the D3.5 in 17.5 pan car, my roll out was usually in the 87 range for an 80ft. straight.
#1432
I have tried that and it will not pull up for me.
#1438
here is a video of the track and me running. I am the yellow/white car (Rob Jensen) who takes the win for the round. However you can see how much faster the other cars are compared to mine.
http://youtu.be/G1jl5IjNpTg
#1439
Ciao micrors4guy,
i'm racing in touring 13.5 blinky and F1 21.5 blinky, i saw your video and i noted that in the straight the car was faster in the second half part of it, in my opinion it means that your fdr was too long, you should try to reduce the pinion of 1 or 2 tooth and as all the other guys already wrote increase a little more the end bell timing.
Ciao
Max
Ciao
Max
#1440
Ciao micrors4guy,
Ciao
Max
Ciao
Max
