Viper R/C Solutions - A New Line of Innovative Power systems!
#407
Weylin,
Can you explain Punch in a bit more detail? I'm not totally clear on it from the instructions. I'm assuming it's not expo, since there's a separate setting for that. Is it something like a minimum-throttle setting on the tekin, or is it like a throttle damping sort of thing? Or something else entirely?
-Mike
-Mike
#414
It's probably well buried in that thread, don't waste your time sifting through pages, just email me at [email protected] and I'll get you set up with a PDF copy of the manual
#415
any chance this speedo will make the ROAR sportsman list before the summer? so that it could possibly run at the Paved on-road nats in July?
#417
Anyone running mod TC? What turn and how does the ESC handle it?
#418
well that's cool i haven't looked at the list in a couple of days, so it could have been there and i've never noticed
so (and maybe this isn't aimed at you, cannon)... what's the difference between the different versions??
VTX10 #6VSVT10001
VTX10-Lite #6VSVT10002
VTX10R #6VSVT10R01
VTX10R-Lite #6VSVT10R02
I'm gathering from reading thru some of this, the "R" is the racing, no motor limit version - but what about the 'lite' versions?? 1s versions???
VTX10 #6VSVT10001
VTX10R #6VSVT10R01
#419
VTX10
ON Resistance
0.00045Ω * 2
Max Input Voltage
17V/ 4S Li-Po
Support Li-Po Cell
2S~4S
Max Peak BEC voltage/amp
7V / 5A
Motor Limit
540 / 6.5T
Dimensions (WxLxH)
30x32.5x14.5mm
Weight
47g
VTX10R
ON Resistance
0.000225Ω * 2
Max Input Voltage
17V / 4S Li-Po
Support Li-Po Cell
2S~4S
7V / 5A
Motor Limit
550 / no limit
Dimensions (WxLxH)
30x32.5x19.5mm
Weight
66g
The Lite versions do not come with the gauge. 1s version still in testing stage.
Manual here
ON Resistance
0.00045Ω * 2
Max Input Voltage
17V/ 4S Li-Po
Support Li-Po Cell
2S~4S
7V / 5A
Motor Limit
540 / 6.5T
Dimensions (WxLxH)
30x32.5x14.5mm
Weight
47g
VTX10R
ON Resistance
0.000225Ω * 2
Max Input Voltage
17V / 4S Li-Po
Support Li-Po Cell
2S~4S
7V / 5A
Motor Limit
550 / no limit
Dimensions (WxLxH)
30x32.5x19.5mm
Weight
66g
Manual here
