Savox Servos
#496
Anyone running the new brushless servos?
How do they rate and are they worth the money?
Savox SB-2271SG
I am looking at the above for my 1/8 scale buggy?
Running a 1258 but am thinking it might be a little weak on the torque side.
Savox SB-2271SG
#497
If you want a little more run the SC-1267MG and save some $
#499
Hey guys,
I got myself a 1258 and a 1256.
The steering servo (1256) doesnt buzz when turned on in center position but the throttle servo (1258) keeps buzzing even when not using throttle or brakes.
Ive played with it for the last 3 hours, servo doesnt buzz but soon as i put horn on, it buzzles. Tried most the End Point Settings + Trim on the controller (airtronics m11x) and still no go.
Is the 1258 suppose to buzz/be noisey on nuetual position for a throttle servo??
#500
From: a very small town in wisconsin that is in the middle of absolutely no where
Hey guys,
#502
#503
Have the 1256/1258 servos in my buggy.
The steering one though seems to stop working properly after 5 minutes on my JQ buggy. At first I though it might be a dud life pack, so bought a new nimh pack to go in it. Charged it up and went for a run today, only to find that after 5 minutes the steering was gone. Is this the sign of a servo about to give up completely, or are there some other things I need to check? The steering is nice and free with no binding, so it shouldnt be under excessive load.
Any thing I should check, and can anyone diagnose my problem outlined above?
edit: I check the spacing and its got great clearence above the chassis, so it shouldnt be heat related either.
#506
I'm a little confused on something. Some servos have different specs for different voltages.
For example the 1268 -
Torque: @6.0v - 208 oz-in. (13 kg-cm) / @7.4v - 361oz-in. (26 kg-cm)
Speed: @6.0v - 0.13sec/60° / @7.4v - 0.11sec/60°
My question is, what do I have to do to get the 0.11sec/361oz out of the servo? Is it as simple as setting the voltage to 7.4v on a BEC? Or do I have to do something else? I'm using a MMM esc and I know I'll have to get the Castle BEC to up the voltage.
#508
Looking at the Savox servos for my Associated B4.1
When you get the servo, are installation instructions included?
I'm concerned about getting the proper travel limits and the thing lined up properly.
Rick
Rick
#509
I just put a Savox 1258TG into my XXX-SCT and it will not stop buzzing. I have messed with the end points and checked to make sure the servo is zeroed, and it doesnt help at all. What is going on? I have heard a lot of great things about Savox servos but as for right now.......not very happy!
#510
For the first part, all you have to do is use the same mounts and direction as the one in your b4. also you might have to shim it a bit. Just use the instructions forth b4 and you'll be ok.
For the second one, it will buzz because it always going to find the center of where you put it at. If you pic up the front of your car/truck and steer one way and let it go back to center it won't buzz.
