Savox Servos
#241
I have this issue with ace servos!
my SR3000 receiver works fine for a min and then the throttle goes crazy and the binding light starts flashing rapidly, this is with a fully charged battery, I thought it was a defective receiver.
What is weird it I have a second SR3000 receiver and it works fine, so I wonder if it is a defective spektrum receiver or due to high drain servos.
is there a thread with more insight into this issue?
#242
Yea I was using two digital ACE servos and only the throttle servo would act up
I tried two battery packs they would always be charged and after about 5 min of playing with the throttle and steering the throttle would go crazy and the bind light on the receiver would start flashing rapidly.
I should probably try with standard servos and see if the same thing happens
#244
It sounds like a high voltage servo issue. I ran into that problem to in the past with certain servos. Like you guys said even if you put a glitch buster doens't take all the glitches out. So I will go back to the analog servos like I have in the past and had good luck with.
#245
yeah I am going to try my sr3000 with two basic servos and see if the issue occurs, what sucks is the receiver is brand new I only used it for a few hours and saw the issue, and then I got out of r/c for a while so now its a discontinued receiver and horizonhobby wants money to possibly fix a new receiver.
The odd part is I have two SR3000 receivers one is like 5 years old and works great the other was like 3 years old and has the issue, it has to be a production defect.
#246
#247
i know on some higher end radios there is a setting for digital to analog. not real sure what to look for, ive never had that problem in a nitro running lipo rx packs, but did have that problem in my 1/10 jammin scrt10, i had to get a CC BEC to adjust the voltage going to servo. savox servos are alittle voltage hungry expecially the 1268 and 1267.
#249
#250
is it radio based or servo based though?
because don't digital servos naturally drain more power?
also I never had lipo packs I had NiMH in my nitro buggy.
I am still going to try two non digital basic servos
#252
servo based, the savox require a constant higher voltage than most servo in my opinion anyway, what radio are you running? i know certian futaba rx's only reccomend 6.0v, the specktrum will handle up to 9.6v. running a futaba rx that is only rated at 6v will starve a savox servo, and will glitch and act all crazy looking for MORE POWER. on my jammin scrt10 i had to set CC BEC at 6.5v to get the savox servo to work as it should, any lower than that would cut power from receiver and servo.
#254
#255
I was running an Airtronics M8 with spektrum at the time and a SR3000 spektrum receiver, like I mentioned I have 2 of the identical models, one works fine one doesn't so it has to be a production defect, and the glitching starts almost instantly, not even 5 minutes of usage and it starts going crazy on the throttle, I was using ACE servos which are 6v but are digital so they should be very similar to the issues some Savox servos have.
what can someone recommend to me as a non digital servo for a 1/10th tourer for bashing, I won't be racing so I do not need sub .15sec, Savox make anything that fits my needs?
