Repair and servo question >
Old 11-03-2010 | 07:32 PM
Default Repair and servo question
Hey guys- I use a Hitec 7965 servo for my throttle. The problem is the screw is totally shredded all the way down into the horn. I guess its a good servo (only one I have ever had) So can I replace the horn and is it difficult? I was thinking of doing that or getting a Savvox. Which one would be good for throttle if I were to go that way?
Falcon422 is offline
Old 11-04-2010 | 04:12 PM
Do you mean the screw that fix the horn to the output axle is stripped out in the head? Or is it on the horn itself where you connect the link to the throttle?
If it is the head that is stripped you can try to "drill off" the head, take off the horn and use a plier to screw the rest of the screw out of the output axle.
Anyway, replacing a horn itself is easy, off with the old and on with a new one The servo is too good to throw in the bin just because of that little screw
Lars in Norway is offline
