FInding the right LiPo - pack? >
Old 08-06-2010 | 03:36 PM
Default FInding the right LiPo - pack?
Hello!
I wonder if someone know a 2s LiPo battery pack that carries at least 5000mAh and 40c+ rating with a height of only 22mm and with a flat bottom?
The topdeck of my car is only 22.5 mm height and I want the battery pack to fit under the topdeck
The battery pack I have now is a IP 5000mAh 30C without flat bottom. I know I can cutout holes for the lumps on the battery, but that is only possible if there's no lumps in the middle of the battery... Like this battery:
http://www.rc-mushroom.com/product_i...ducts_id=17095
Skynet is offline
Old 08-06-2010 | 03:43 PM
This should do the job
http://hobbyking.com/hobbyking/store..._40C_Lipo_Pack
Cheers
crusey_aus is offline
Old 08-07-2010 | 08:52 AM
Sorry I didn't mention, but the battery need to be a hardcase as Roar and Efra only accept these type of packs.
Skynet is offline
Old 08-07-2010 | 10:31 PM
One note that if you are going by ROAR rules then it has to be an approved hard case pack. So a hard case pack from HobbyKing will probably not work for you as I don't believe they have been approved by ROAR. You are pretty much stuck with the more expensive name brand car oriented packs.
kcobra is offline
Old 08-08-2010 | 04:06 AM
Yes, that's why the battery "crusey_aus" recommended doesn't work.
Skynet is offline
