Need help finding charger for receiver pack! >
Old 07-01-2010 | 11:35 AM
Muggydude's Avatar
Default Need help finding charger for receiver pack!
I've been looking all over, but I cannot find a set of banana plugs with receiver leds on it! (Same as the connectors on servos). Anybody have a link?
Muggydude is offline
Old 07-01-2010 | 11:55 AM
token's Avatar
http://www.amainhobbies.com/product_...arging-Adapter
http://www.amainhobbies.com/product_...nector-Adapter
http://www.amainhobbies.com/product_...m-Banana-Plugs
token is offline
Old 07-01-2010 | 06:43 PM
I am using this:
http://www.xceedrc.com/product/105207
More or less the same as posted by Token...
ganymede is offline
Old 07-01-2010 | 09:00 PM
iznasty's Avatar
I use the Commom Sense Tarantula 8-in-1 Charging Adapter that token posted, only thing missing is the glow plug adapter.
iznasty is offline
Old 07-02-2010 | 09:55 AM
kman16jr's Avatar
Wink charger
Just get the duratrax 200,They cost like 40 bucks and have a built in charge jack so you never loose or forget the charge cable.Here is the link: http://www.amainhobbies.com/product_...t-Peak-Charger
kman16jr is offline
Old 07-02-2010 | 11:01 AM
Roelof's Avatar
Get a 1 meter servo ectension cable and 2 banana plugs.
Cut it in 2 halfs at about 15 cm from the servo plug, that you kan use on a battery pack or a servo cable replacement.
On the ends of the 85cm cable you have to mount the banana plugs what will give a simple and long enough charging cable.
Roelof is offline
