brushless motor?
Old 05-21-2010 | 06:45 PM
newuserlosi8t's Avatar
Default brushless motor?
i run a 5000 mah 2cell lipo with a losi 6400 kv motor how hot do brushless motors get
newuserlosi8t is offline
Old 05-21-2010 | 07:01 PM
well anyways mine is real hot to touch after ten minute runs is that normal
Old 05-21-2010 | 07:23 PM
racer1812's Avatar
Super Moderator
6400kv is a pretty "hot motor" no pun intended. Motors with that high of a kv may not like to run that long before getting hot. Gearing is the key, and you really should use a temp guage to check the temp on the motor. "hot to the touch" really doesn't work with BL motors as they have a fine line between running all day and going poof from heat. Depending on the brand 170 deg is safe. at that temp you can't really tell by touching it....
racer1812 is offline
Old 05-21-2010 | 07:43 PM
well i run nitro so i have my temp gun. whats a safe run temp? the guy i got it from went on the computer with me and set it up for it is in sport with reverse its the wifes what a safe and unsafe temp just a genral rule before i can go to the track and get all the little questions answered and some hand on demo
and its in a slash it is a losi brushless think exelerion is how u spell it not shure
Old 05-21-2010 | 08:01 PM
racer1812's Avatar
Super Moderator
The Losi site should tell you what they recommend for temp on their stuff. Every Man. has a different "safe" temp. I know Novak says 165 for theirs and Castle says 200deg for theirs so there isn't really a genereal safe temp. but they all seem to be safe at 170 deg and below. I've seen Losi stuff run and they "live" at the 170deg mark. Like I said before when you run motors that are that "hot" you won't always be able to run them for long periods of time without a break... a 17.5 BL motor can run all day but my 5.5 stuff is meant for racing...<8-10 min... there are a ton of factors that can play into the run times with hotter motors.....
