Problem with: 4PK--MM pro--Servos not functioning correctly.
Hi!
I try to put this in so few words as possible.
I have some issues with servos not functioning correctly with my Castle Mambamax Pro ESC.
I have an Futaba 4PK controller and i have tried Savöx and ino-lab servos and they doesnt work correctly when i steer, with the Savöx servo the red led on the receiver start blink and the ino-lab wont centrate correctly, i did try my BLS451 servo from my racecar and it functioned perfect. i have tried the two settings on the transmitter for the servos "general" and "bls digi" modes without any difference.
I also tried all theese servos in my race car with the same receiver but with my LRP SXX ESC instead and all the servos works flawless!
I need some help on this issue, i have also tried another Mambamax Pro without succes.
Happy for answers.
Happy for answers.
are you in HRS mode? this mode does not work with analog servos
try ppm mode if that is the case
or
up the voltage in the MM using castle link to 6.4v
also IIRC some other setting in there has something about high amp draw servos
or
