spektrum receiver
I am running a spektrum receiver and I have noticed that as I get low on a battery that sometimes the car will stop for a bit if i try to turn while being on the throttle so I am wondering if i need to using a rxbattery with this RX cause i never noticed it with my old 27mhz one.
And if I am can you suggest a cheap one
Does anyone know if the receiver have a low voltage failsafe thats a fairly high voltage. Cause if I pick up the car it will run just fine its like the motor draws to many amps and drops the voltage temporarily
These guys called it a brown out warning or something - caused by voltage dropping below 3.2v. Watch at ~4:30min when they start talking abouit this. No one said fail safe. This implied you've got a prob somewhere that may be interrupting power (bad connection) or the batt you're using isn't up to the task of keep ing voltage high enough to avoid this -
http://www.youtube.com/watch_popup?v=PwnM9pBH9QM#t=233
This was on the SPectrum site btw.
