SR3300T antenna
Old 04-20-2010 | 11:05 AM
Wingnut44's Avatar
Default SR3300T antenna
I have an SR3300T on the way with a damaged antenna and am wondering what I need to replace it. I've read its not just a wire like the FM systems I'm used to, and that its a coax wire that plugs in. Where can I get a replacement?
I see that Amain has a case for a SR3100 and an antenna for 7$, is this the same antenna I need? And is it available somewhere without the case I don't need?
Dan
Wingnut44 is offline
Old 04-20-2010 | 04:49 PM
It is just a straight wire and can be replaced if you are confident with soldering etc...
Take the cover off and you will see where it goes
The replacement 3100 antenna pack uses a slightly different type / length of wire but it may work
I broke mine and sent it into a local spektrum agent, they replaced it for for $30
Cheers
crusey_aus is offline
Old 04-20-2010 | 11:17 PM
Wingnut44's Avatar
Could someone let me know what the length of the antenna is? I'll probably attempt the job myself if its just a normal wire.
Old 04-21-2010 | 12:57 AM
9.1 cms from the circuit board
Cheers
