DX6i clarification and tail servo question >
Old 03-03-2010 | 12:38 AM
Questions?? DX6i clarification and tail servo question
While I am still perfecting my hovering, I'm already looking into the future for which upgrade would make the most sense next. I currently have the Exceed RC 2.4ghz 6-channel transmitter, and although programmable via PC(T6config), it is very basic.
I do like the DX6i a lot, but I have read many conflicting articles and postings about the DX6i transmitter and a T-Rex 600 E version. Some say the DX6i works perfectly fine with 600-class, others say you need a 7-channel. Which is correct? Since the T-Rex 600 is the class that I will eventually focus on, I want to make sure my transmitter can do the job, without having to buy another one once I am ready for the T-Rex 600.
The other question I have is in regards to noise coming from my tail servo:
I have the Detrum GY48V gyro on my EXI 450 Alu V2. I can hear a constant buzzing sound from the tail servo even without rudder input, is that normal? I am using the following tail servo: T-Pro MG90S 9G, which is supposedly digital, therefore I set my gyro to DS mode ON.
I actually have an Align DS420 servo on the way, but I am curious about this buzzing sound in general...
Thanks so much in advance!!
EmRen is offline
Old 03-03-2010 | 05:57 PM
No one??
EmRen is offline
Old 03-03-2010 | 10:06 PM
Unhappy
Boy, oh boy! I know it's annoying to help people that are not as experienced, but maybe you should not have a forum for help then. Because this is apparently a place were you won't get any...Just remember, you were all n00bs at first. Good Luck with this "oh so helpful" forum
EmRen is offline
Old 03-03-2010 | 11:10 PM
wikedgmc's Avatar
did you post in the flight forum?
Try that and see what happens
Not all questions get answers right away
wikedgmc is offline
Old 03-16-2010 | 05:35 PM
Buzzing is not unusual with digital tail servos. My question to you is how does it hold? Looks like a JR 770, does it hold the tail well in heading hold?
I just having got the Trex600 am glad I have a 7 channel Tx. Although you could get by with 6 channels (3 cyclic, 1 rudder, 1 throttle, 1 heading hold on/off/program gain) I can use the 7th for a servo to adjust the carb mix, or to plug in power to the receiver without using a y-cable.
So i suggest you get a DX7. I have the Futaba 7C, but cannot take advantage of all the nice bind-and-fly flying things like the Blade msR. The DX7 would be the ticket!
wackyhobby is offline
Old 03-17-2010 | 04:26 PM
Before you start bashing the users of this forum, remember it is basically a car forum, not a flight forum. It is unlikely that the car people would of been able to help you. I see someone did point you to another forum one day later. That is not bad response for this portion of the forum.
Doog is offline
