Cheap Digital High-Voltage servos
#16
sweet man!! hope to hear how they hold up in race conditions !! keep us updated
#17
been running the turnigy 767 steering and 300 throttle in my rc8 and rc8t with 2s lipo direct about 1 gallon on each chassis. besides having to raise them about 4mm to clear the chassis, they are amazing. the steering speed is faster than i can physically turn the wheel of the tx. i set my expo on the helios up to compensate. the throttle has so much tourque by brakes are finally doing what they are supposed to do. i almost did a front flip on pit lane when someone stopped short. the 767 specs are the same as the new $200 ko servos. i will be running these for as long as i can find them.
#20
yup, definitely has enough wire too. i run the hv300's in throttle, its a tad slower which i like cause i expo my throttle anyways. very impressed so far. just need a weekend with no rain for once.
Turnigy HV-767: $60
Operating Speed (7.4V): 0.118 sec/60° degrees at no load
Stall Torque (7.4V): 31.00 kg.cm (430.5 oz/in)
KO Propo RSX: $199
@7.4V: 0.11 S @ 60°
@7.4V: 436.1 oz-in (31.6 Kg-cm)
Turnigy HV-767: $60
KO Propo RSX: $199
@7.4V: 0.11 S @ 60°
#21
still running them. i had a 300 that locked up at psycho and a 767 that spun off a pinion inside. both warrantied and back again for more, i swapped out one of the 300's for a 767 since i won't be running lipo anymore and wanted the throttle to be a bit quicker again.
