3PKS synthesized w/ crystal reciever >
Old 01-13-2010, 11:39 AM
cla5675's Avatar
Trader Rating: 49 (100%+)
Default 3PKS synthesized w/ crystal reciever
Hey, all. I am looking to upgrade from my current 3PM radio to a 3PKS. However, I have 10 FM crystal recievers and I don't want to change to DSM or buy a bunch of synthesized receivers. So, I was wondering if anyone has tried a 3PKS with a synthesized module with a crystal reciever. If so, is there any glitching or any problems when using the synthesized radio with a crystal reciever? Any input is greatly appreciated!! Thanks!!
Troy.
cla5675 is offline
Old 01-13-2010, 12:49 PM
lil-bump's Avatar
Trader Rating: 89 (100%+)
Troy.
That should be no problem. I use a Ko helios with a synthesized (Jr module ) with a KO helios cyrstal receiver with no problem. As long as both are compatible and on the same frequency it should not make a difference.
The only problem you may run into is some of the older receivers can not run in super fast response mode.
lil-bump is offline
Old 01-13-2010, 12:51 PM
Trader Rating: 21 (100%+)
I have just the regular 3PK and thats the setup I use - synth tx and either crystal based rxs (over 2 dozen) or a synth type rx (one). Nearly all of mine are PCM rxs. I've never had a prob. Not sure what exact diffs are between 3PK and 3PKS, so my experience my not be helpful.
Duster_360 is offline
Old 01-13-2010, 01:18 PM
Trader Rating: 52 (100%+)
I run a 3PKS synth and about 15 crystal receivers...mix of dual and single conversion futaba and hitec's... all of them work as well as the synth receiver that came with the radio.
shultz is offline
Old 01-13-2010, 01:35 PM
cla5675's Avatar
Default Thanks!!
Thanks, guys!! That's what I needed to know. Looks like I'll be on the hunt for a 3PKS now!!
Troy.
cla5675 is offline
