CHARGER QUESTION PLEASE LOOK>>>>>>>> >
Old 12-20-2009 | 11:17 AM
Suspended
Default CHARGER QUESTION PLEASE LOOK>>>>>>>>
Im getting this charger from ebay is it good?
http://cgi.ebay.com/Poli-B6-Lipo-Bal...item2a036c3b97
Clairvoyant973 is offline
Old 12-20-2009 | 01:03 PM
Its looks like its a knock off of the HC Accucels and other chargers.
Looks like you're going to be the 1st with one......you tell us.
Duster_360 is offline
Old 12-20-2009 | 06:05 PM
Suspended
I got this charger from ebay i bought it and i wanted to know if its any good and i have no clue what you mean a knockoff version
Old 12-20-2009 | 06:35 PM
Knock-off = copy
http://www.hobbycity.com/hobbycity/s...(USA_Warehouse)
Has same specs. The buttons, the external wires and balance ports, these layouts are the same, look familar? Case is bigger and different color, bet yours has a blue backlight too just like this one.
Not saying their not good, I have one of the Accucels and its a good charger, just haven't seen the version you bought before.
I think the Accucel is not the orig either, its a copy of the iMax charger.
Old 12-20-2009 | 06:40 PM
Suspended
YOUR right lol
Well idc as long as it charges my batteries im fine
Old 12-20-2009 | 06:47 PM
Its a good charger, you won't be disappointed, it has a ton of features you normally wouldn't get in an inexpensive charger. I've enjoyed using mine and it'll be a yr old in about 2 weeks.
Old 12-20-2009 | 06:51 PM
Suspended
oh good i was going to pay 80 bucks for a charger but i was like WHY if i can spend 30 bucks and its good to go and has a balancer
Does that charger need a power supply
Old 12-20-2009 | 07:07 PM
Yes, it requires a power supply, its a DC charger. Anything with 11-18v and about 6 amps continuous work run the charger at its max power.
Old 12-22-2009 | 02:34 PM
I bought this Ofna Prolux power supply. Spec 9-14v with 18amp power supply. You think this is adequate?? I'll be charging a Thunder Power 5000mah 40c Lipo with possibly buying another and charging that also.
lexroc45 is offline
Old 12-22-2009 | 02:40 PM
Thats plenty even for a 6S (25.2v x 5a = 126 watts) for a 1C charge. That power supply has 14v x18a = 252watts.
What cell count, 4S?
Old 12-22-2009 | 02:45 PM
avrcguy's Avatar
There's a million of these chargers out there, under just as many names. It will probably be just fine. Though you probably could have found it cheaper elsewhere.
avrcguy is offline
Old 12-22-2009 | 03:30 PM
It's a 2s. However I like the flexibility the Accucel-8 charger gives me just in case.
lexroc45 is offline
Old 12-22-2009 | 03:33 PM
Going to power an Accucel-8 if I didn't already mention. I'll admit, looks were a part of the purchase in addition to the power. lol.
lexroc45 is offline
Old 12-22-2009 | 05:17 PM
Your Accucel-8 is a 150 watt charger, your power supply supplies 252watts, you're in great shape, you can run the charger at full power anytime you need to.
I like the way my Accucel-6 looks too, esp the backlight.
