How to solder correctly (a not so brief lesson)
#436
#440
Update
When i went to radio hack to get solder a dad and his boys walked in looking for solder....for deans plugs....having the same problem.....shared the knowledge i learned here....about 63/37 solidifing faster....about flux.....felt awesome to pay it forward.....
#441
Success!!!!!!
I followed all the advise here and soldered the deans right up! Flux and the right solder made all the difference.
Even switched to my el-chepo iron (25watt pen type) instead of my 40/100watt gun.
http://www.rctech.net/forum/members/...urecomment3329
The gun seems to only be heating if pressure is applied to the tip which i noticed after I tinned the first wire. Any ideas what could cause this?
#443
Yeah plumber flux is more acidic... It can work, but is not ideal.
As was said, some combinations are not very compatible.
And it is always good to pass along what you learn.
Your soldering iron woes may be due to a faulty heating element, or the tip is bad. A new iron may be needed.
Keep up the practice, you are doing good, and practice will make you better.
#444
I always use a flux dispensing pen, bit like a Sharpie, to apply flux;
Always gives excellent results, and is also great for cleaning up PCB's that have a lot of grime etc on them.
Then when cleaning up, if you want to remove any I use one of these;
#445
Thanks for putting this up and keeping with it Marine6680. I just recently found it and after reading about the difference in 63/37 solder decided to pick some up. Hard to believe that slight shift in the mix makes such a big difference in the connections but I checked some that I did just a few days before I got the 63/37 to one I did after and it does look different and feels different.
Oh and really long time lurker and this got me to do my first post here.
#446
Those Flux pens can work pretty good. Definitely less mess when using them. I find them less helpful on old dirty connections as they do not deposit enough Flux to break through a lot of corrosion/oxides.
How many years has them been going now? A long time...
I am just glad I can help people.
#449
FYI, it looks like the LRP HighPower (RRP of £180.99 here in the UK) is a rebranded Quick202D (which can be found for £98).
The included tip might be a good deal smaller, though, but even counting the price of an additional tip, still a good deal!
31Likes
