Novak GTX replacement capacitor >
Old 09-30-2009 | 01:13 PM
Default Novak GTX replacement capacitor
Hello , I just got a used gtx and the capacitor look damage with kink and ballon and flat spot on it . I got one from my local electronic store but its 2.5X the size the the novak one.
I just want to be double check here:
the novak cap specs is 4700Uf 10V 105 celcius and you can read M CE FC
the replacement I got is orange and spec are : 4700Uf 10V (M)130 celcius and you have a rectangle on it following a GX and 34 P(8)
Can I use my replacement one? its bigger only because its rated at 130 celcius?
im pretty sure that will do the trick but I want to be double check in case the novak cap or the replacement I got are special or anything else.
thanks
Group B Monster is offline
Old 09-30-2009 | 03:09 PM
The Evicerator
I would recommend against going with a capacitor you just happened to find that looks like it has the same voltage/capacitance specifications as the stock Novak capacitor.
There's a spec that is not rated on the capacitor that is called ESR which has to do with the capacitor's ability to cycle between charge and discharge.
I would simply recommend picking up a #5679 Transcap Module for your GTX:
http://www.teamnovak.com/products/po...ors/index.html
Steve Weiss is offline
Old 09-30-2009 | 04:12 PM
thanks steve , Off course I will replace with the novak one , but I wont get it before a least a week maybe more. I was just wondering if maybe the other one can do the trick for a week or 2 , the time I receive the novak one. Its been 2 week since my esc broke and I see the end of the season comming very fast here in the north, having to wait again a week or 2 is killing me, plus I have to test this used gtx to make sure its work fine.
But if its critical and can damage the ESC I guess I will wait.
The seller test it with the kink ,flat spoted cap and said its work , but I just dont want to take the chance to run it with that cap
