Deans, Bullets, or Direct Solder?
Hi, I'm looking to get the path of least resistance from my ESC to my motor. Right Now I'm using bullets that are well corroded for the connection. Should I replace the bullets with new ones? Or should I put deans on it, or is it worth it to go for a direct solder?
Direct solder is best for least resistance but I prefer a good quality bullet connector such as Caslte's CC Bullets just for ease of maintenance down the road. You likely will not notice the difference between a good quality bullet and direct connect.
I have run Deans for years on everything from 1/18th to 1/8th electric and never had a problem. Car Action tested plugs sometime back and Deans was the winner; the Sermos power poles were second. I think another company makes these now. The resistance was equal to direct solder. The benefit is you can disconnect quickly if needed; can't do that with direct solder. IMO
Thanks for all of the help
but from what you guys are saying, it goes in order from direct to bullets, then deans.
Ill probably go to direct just because I don't plan on changing anything in this car once I'm done building it.
when i was brushed i used deans...
switched to brushless 13.5T... switched to bullets(cause there is 3 wires)
switched to BL 8.5T and now its soldered. And only due to the fact that my best mate is an auto electritian thats a gun with a soldering iron and does a ultra clean job.
I liked the bullets for ease of pulling the motor or speedy out seperately if needed..
Those Deans knock offs (HC?) are diff, several complaints on RCMonster about them gettting hot enough to go soft to where the metals pieces move around.
I think I remember something from a few years back, saying that Deans are good for 100 amps... I think.
I do know that Deans has less resistance than the equivalent amount of solder...
Without a jig, they're kind of a PITA to do, though
The only place I used bullets, is brushless motor wires...
