Spektrum SR3000 Receiver Not Binding?
I'm having an issue with my receiver not wanting to bind. Here's the setup:
Spektrum DX2.0 transmitter
Tekin FX-Pro ESC
Spektrum Z270 servo
4-cell NiCd 1600/1700mAh
27-turn brushed motor
These are mounted in my Legends car. This is the first installation of the receiver in any car. I press and hold the button on the receiver, turn on the switch on the speed control, the green light flashes on the receiver, and I release the button. I press and hold the button on the transmitter, turn it on, and the green light flashes, then goes solid. However, the receiver never seems to bind; the green light remains flashing. If I just urn on the switch on the ESC, the light on the receiver never comes on at all. I got it to work like once, but after that, whenever I turned on the car, I wouldn't get the green light on the receiver.
Now, in my pan car, I have the following:
Spektrum SR3000 receiver
Spektrum Z590 servo
Novak GTB ESC
Novak SmartBoost
SMC 1s LiPo
Novak 13.5 Brushless motor
This setup has no issues; the car works fine. I want to use the same transmitter for both cars. I even tried hooking up the 3200mAh/2s LiPo (for more voltage) to the Legends car receiver, thinking maybe the low voltage was not getting to run the receiver, but it didn't work. However, both the 1s and 2s LiPo's, and my 4-cell packs all work fine in the pan car.
I also used the Spektrum SR3000 receiver in the pan car along with the Tekin (with a 19-turn brushed motor and 4500mAh 4-cell NiMh's) - that's now in the Legends car - with no previous issues.
Could the receiver in the Legends car, which is barnd-new/never been run, be bad?
EDIT: Tried the new (second) receiver in the pan car with the Novak; no difference. Still couldn't get it to bind. Hooked my trusty ol' Futaba AM receiver (it's 17 years old...LOL) to the Tekin, and all's good. Looks like maybe that receiver's bad.
Tekin FX-Pro ESC
Spektrum Z270 servo
Spektrum Z590 servo
Novak GTB ESC
Novak SmartBoost
SMC 1s LiPo
Tekin FX-Pro ESC
Spektrum Z270 servo
Spektrum Z590 servo
Novak GTB ESC
Novak SmartBoost
SMC 1s LiPo
Tekin FX-Pro ESC
Spektrum Z270 servo
Spektrum Z590 servo
Novak GTB ESC
Novak SmartBoost
SMC 1s LiPo
http://www.horizonhobby.com/Articles...ArticleID=1923
Make sure you don't have the polarity reversed on the ESC going into the receiver as demonstrated in this video. Check the 2:50-forward portion of the video, demonstrates this exact issue.
