-   -   Hyperion EOS 0606i (https://www.rctech.net/forum/radio-electronics/316337-hyperion-eos-0606i.html)
madweazl 09-16-2009 04:12 PM
I really like my 0606i but I only use it for my mini, rx packs, and starter box packs.
Duster_360 09-16-2009 05:23 PM
All E RC has the 1210 on sale for $85 (180watts, 10amps) -
http://www.allerc.com/product_info.p...oducts_id=2785
If you use the Hyperion LBA10 balancer, you can monitor cell voltages on the 1210 charger, they were designed to work together.
Dave H 09-16-2009 06:06 PM
Originally Posted by Zerodefect (Post 6354310)
I use an optima 12v car battery as a power supply. Never fails. Even though my 0606i is AC/DC I usually hook it up to my battery because track power is pretty sketchy. I plug a small battery tender style charger to the optima and plug that charger in to keep the 12v optima car battery charged (if needed).
I thought I was about the only guy that did that. But I just use a marine deep cycle battery, wish I had an Optima gel cell job if that’s what you mean. I only do it outside and big inside races though. Can’t beat the power quality & reliability. No worry about generators running out, cords getting yanked, overloaded circuits. I have an inverter for the iron even. Comes in handy when the wind picks up! :D:D
And it’s always good for a few laughs, quite the Rube Goldberg set up. :p;)
+ on the Hyperion 606 for 1/10 scale. I’ve got the little DC only one, nice and small. Finishes the CV portion faster than anything I’ve tried. Need to grab another one.
justsomeguy 09-17-2009 08:03 PM
bit of a thread jack..
I have the Hyperion EOS 6061i ac/dc charger... Read the manual, hooked up a 5000mah 2S Zippy and off I went. Charging at 5.0 amps..It was done when I got home.
Today I tried it on my mini battery. 1600mah 3S zippy... Its been hours since it started. The charger says it is charging at .16 amps.
Shouldn't it be 1.6 amps?????
I thought I went through the menus right...Is it seeing something wrong with my battery or something?
Tony
racer1812 09-18-2009 04:49 AM
Tony
First you left your lipo charging unattended:eek: BAD idea! Second, how many hours?? It's a normal part of the charging to see .16amps on some packs as it's almost full but on a pack that small it should have terminated the charge within an hour I'd guess ( I have a 610inet)
Read your post again..did you set the mah for the pack to 1600 or did you put in 160 by mistake as that would take forever and set the charge rate at .16 amps automaticaly.
justsomeguy 09-18-2009 01:37 PM
I understand bad things happen to Lipos. But I dont have the kind of life where I can watch grass grow. If I wanted to be there the whole charge cycle I would have bought a treadmill or generator for my bike :D
I did have it set at 1600 though. And it did take hours. In fact when I left for work it was still going. No 'battery charged' or anything like that.
I am going to run that sucker down again and attempt it once more
Tony
Duster_360 09-18-2009 02:00 PM
Tony
With some zippys, cells get way out of balance, especially with a deep disch and depending on your balancer, it can take hours and hours to get them back in balance and charged. Ck cell voltages with a dvm using the balance tap and see how far apart they are before charging. My Neus rarely get more than 3-7mv apart (.003 - .007v) and if I don't pull a lot of mah out they usually won't show any diff.
justsomeguy 09-18-2009 04:21 PM
Well last night it was just a PITA. Today I ran it down and tried to charge it. Iit said one cell was way out. Tried it twice...same result. Third time it acted normally..Maybe I should let it cool down 15 minutes before charging.
And BTW, its at the 1.6amp rate now! :D
I take it back... its down to like 20ma rate now.....and its been forever. God I hope this charger is ok and its a one time thing with this battery....
Zerodefect 09-19-2009 09:18 AM
Sounds like that battery is dieing. I had a maxamps puff and die the same way. The charger will charge a little then try to balence, if the pack is bad it won't balence, and the charger will keep trying to balence before charging again. Its a good safety feature.
justsomeguy 09-19-2009 01:16 PM
Hm
The pack could well be near the end. It was used, and by the condition of the car when i got it, WELL used..
I am getting some new packs so we'll see
T
curtisp 09-20-2009 07:53 AM
Tony
I understand that you might not want to or don't have the time to sit around watching grass grow or babysitting your lipos while they are charging...but I would definitely recommend using some sort of lipo sack or other fire resistant container while charging (maybe you already are using one.) Better safe than sorry.
BIG RE 09-20-2009 03:23 PM
I just got a 0606i, does this DC cord come off somehow? It looks like it can but I don't want to damage anything. Thanks.
