Servo problems or Reciever problems, >
Old 06-21-2009 | 07:37 PM
edwintklee's Avatar
Default Servo problems or Reciever problems,
hi guys,
just checking if any 1 had encounter this problems before.
i was using a spektrum pro Rx sr3001 with futaba 3003 servo,
its use to be ok no problem, but lately, i notice the the servo was unable to get back to its center position, it will take some time to get back like 2 - 3 seconds. which means 1 lap you can get a straight line , 2nd lap you wont get straight line...
i have cross check with other 3 servo (3003) same problem, but if use KO propo servo, the servo will work fine....
i even tested with other spektrum Rx, same problem with futaba servo but no problem with KO servos...
edwintklee is offline
Old 06-23-2009 | 05:15 PM
edwintklee's Avatar
any comment??
Old 06-23-2009 | 05:19 PM
rc-mike's Avatar
It is probably the servos. S3003 servos are pretty low end servos and have some centering problems.
rc-mike is offline
