Tekin RS PRO
Old 08-13-2009 | 06:28 PM
  #16
R/C Tech Elite Member
No, not unless you will run smaller turn motors in the future (5t and less), there is no performance gain.
flame56mx is offline
Old 08-14-2009 | 06:08 AM
  #17
Originally Posted by callender89
Quick question, is it worth it to shell out the extra $$ for the rs "pro"? i will be running 17.5 or 13.5 in an SC10.
The only reason you would NEED a PRO is if you plan to race modified class using 5T motors or less. The regular RS is MORE than enough for your needs.
AreCee is offline
Old 09-20-2009 | 11:19 PM
  #18
riene5's Avatar
I know they act as a heat sink, but does any one run some heat shrink around at least on of the battery posts?
If one of your battery wires came loose off the speed control and accidently came in contact with the other, this could be the end of a lipo for you.
I know I should learn to solder better (I'm getting there), but this could be a cheap form of insurance.
BTW, if I'm running 17.5, surely some heat shrink around one post (and only where the wire is solered on) shouldn't harm the ESC too much?
riene5 is offline
