brushed motor temps
Old 04-14-2009 | 02:56 PM
pakk's Avatar
Default brushed motor temps
What's max temp a brushed motor should be?
pakk is offline
Old 04-14-2009 | 03:02 PM
Cpt.America's Avatar
I raced brushed motors for YEARS, and never worried about temperature once. I geared for torque, top speed, and battery run times, and that was it.
Cpt.America is offline
Old 04-14-2009 | 05:53 PM
150 max
b4wires is offline
Old 04-14-2009 | 06:07 PM
racer1812's Avatar
Super Moderator
Some say max. 165
racer1812 is offline
Old 04-14-2009 | 06:10 PM
racer1812's Avatar
Super Moderator
You can't do that with brushless, you can burn them up if they run too hot. I too ran brushed for almost 20 years but temping a BL motor is the only way to make sure it is set-up correctly.
Old 04-15-2009 | 08:39 PM
I feel it's best to temp both Brushed and brushless motors. This way you know where your at for gearing.
b4wires is offline
Old 04-16-2009 | 03:53 AM
What I've read is 160F, so its prob in that vicinity. I'd try for a setup that was a little cooler if poss rather than try to run at or near max. Maintenance and motor life will not be the best at max temp conditions.
Duster_360 is offline
Old 04-16-2009 | 04:22 AM
For brushed motors I have always used a thermometer for stock and spec, mod can be a different story as you don't always use all the power, I am not the one to be giving advice or opinions on mod however as it isn't my class of choice
This is some of the best information I have seen on here regarding motor temps, gearing and setting up you car/truck for your brushless system.
http://www.rctech.net/forum/5656941-post16.html
Cammer is offline
Old 04-16-2009 | 09:15 AM
Yeah thanks.. but we are talking about brushed, not brushless.
Old 04-16-2009 | 07:16 PM
racer1812's Avatar
Super Moderator
OOOPS
Old 04-16-2009 | 08:58 PM
I ran brushed mods motors last year. I like to run them around 150F to 160F tops on temp.
b4wires is offline
