DX3R with lipo
#16
If you're not regulating the voltage into the receiver and not using a High Voltage servo you're going to shorten the overall life of your servos. You also have to remember that the DX3R's electronics were designed to operate at around 6V Max. You're adding considerable voltage there that could potentially damage and shorten the life of your transmitter. Not trying to be a downer here but there are consequences to what you guys are doing. Why do you think you need an adapter for US electronics in countries that use 220v instead of 110v? Granted that's a bit of an exaggerated example but a valid one.
I know there are downsides to running a Lipo in the 3R, but if I happen to dump the transmitter, then it will give me a reason to get the 3S. But ya can't tell me there isn't any excitment in pushing the limits :-)
#17
These radios are such a small draw heat is not an issue, and about the voltage fresh good AAs will be well over 6 volts. If your really worried about the extra voltage hurting something just use a 5 cell flat RX pack.
The reason we want to use other types of batts is because we allready have them and they are rechargable.
No one can argue a 1700mah pack is going to last longer and be cheaper in the long run than AAs.
I doubt horizon would warentee my radio anyways, The wheel isnt stock, the trigger has been melted and good lord like every hobby product ive ever owned I took It apart.
LOL Hi-voltage servos, All Good servos run fine on 2s lipo
#19
Radio's are DC voltage, i do agree, overvolting a radio doesn't sound smart to me. specially by this much.
#21
I run 2600 NiMH AA's in my radio (not a DX3R), and unless the lipo math on mAh applies here, 2600>1700... As for cheaper, 4 of the AA's I use came free with my charger
Now, I will say it would be more convenient to hook the pack up to my charger at the track in a pinch rather than borrow or buy AA's...
#23
Wow this thread is dead. Anyways JGruber sold all of his racing gear a month and a half ago but his DX3R with lipo was going strong. I am too not one to fix whats not broken but am for sure curious. I am using NIMH rechargeable batteries and yes they are a little heavier however I see no reason to go with a lipo battery for weight reduction with the DX3's being so light as it is.
#24
hey i have a middle of the road solution. i run the Enerdizer lithuim aa's and i love them and they last for ever in my radio just switched to an 3r. i know these will pull over 12 hours in a m11. and that is 8 of them.
Last edited by Drain Bamged SR; 01-14-2011 at 03:30 PM. Reason: forgot to add i did not realize this thread is close to 2 yrs old
#25
I'm looking for some feedback on what people were doing late 2010. my dx3r has been running on 4 NiMH bats successfully for some time and Im wondering if it is worth the mod. It literally takes 5 min to charge these batteries and it last for 6 hours. To me this seems more than ideal. I labled them to rotate the charging position in case they are giving a false charged signal to my charger(charging one or two of the batteries leaving the others untouched). I'm not really sure if this makes a difference with NiMH. Input and "mochary" is taken well, to a certain extent.
#26
I've used everything from the cheap NIMHs from Harbor Freight to premium Sanyo Eneloop AA batteries. Oddly enough, the Harbor Freight Nimhs lasted longer, and charge cycled more often than before rolling over dead than anything else. With them being so cheap, never saw a need to go LiPo with the TX.
#27
I have been running over 8v in my DX3R for more then two years with zero issues.
I did it originally to gain radio range which it did very well. The comment made about the radio only being able to handle 6v is completely untrue there is not one component in the radio directly related to the input voltsge rated for less then 15v and the radio could never generate enough amp draw to even warm up a lipo.
As with any lips use cation should always been used but in this case as far as I have been concerned the higher voltage has only benefitted and saved me from buying a futaba.
#29
Honestly I don't. My radio works perfectly with NiMH rechargeables. I don't know what their reasoning behind going LiPo was but I know what mine would be. Even with a regulator you could have heat issues. I wouldn't want that inside of my radio honestly. Plus a single-cell LiPo has too low of a voltage output, meaning you would HAVE to use a 2S, and you're right back at the regulator again. Plus the goal was to make this a radio that ran off of 4AA's.
Got to say I agree with you on the using NiMHs though, people see the mods we used to to back in the day with AM/FM radios and think "boy, that's a good idea" not knowing enough to know that the old radios really benefitted from such a mod, whereas it's counterproductive in all modern 2.4ghz TXs as most run on a combination of 5 and 3.3v, which has to be got by regulation. Because radio manufacturers are cheap, the regulators in such radios are invariably cheap linear items - rather than the vastly superior, but slightly more expensive switching regulators - which struggle with no heatsinks and in a sealed case to dissipate the unwanted energy even with alkalines and fully charged NiMHs, never mind a lipo. This is probably not so much of an issue with the 4 cell radios but 4 cell makes it even more unnecessary to run a lipo.
LiFe is a good idea due to its lower voltages, but LiFe's power:weight/bulk ratio is quite poor. There's just no need for a Li of any kind.
#30
a switching regulator would not cause heat problems, and they don't interfere with cheap chinese radio so I would be very disappointed if they interfered with a Spektrum.
Which would seem to preclude any possible range increase from a higher voltage battery much past 5 volts, perhaps 5 plus any associated regulator drop out.
If so this can fairly easily be accomplished in a DX3R by adding a 5th nimh battery, as there are 2 additional spots under the cover past the standard 4 spots. Or 4 AA lithiums with no mods as some do. With little risk of killing the batts (nimh only obviously) by accidentally leaving the radio on, or having a lipo puff damage the radio.
