Broken dx3s scroll wheel >
Old 02-18-2009 | 12:48 PM
fat500's Avatar
Default Broken dx3s scroll wheel
Please read this. I hope it helps.
The problem with the scroll wheel lies in the instruction manual.
The wheel works fine IF you only push it in on the left side ONLY. The right side of the wheel is fixed in a rotating pot and the left side activates the switch.
If you try to push it in by pressing on the right side you can break it if you push too hard. The manual should state to only push it on the left side. To their credit, if you look at the pic in the manual it DOES show the thumb of the person on the far left of the wheel. They should just state this clearly in writing. My first instinc was to push it in the middle and after i played with it i figured it out.
I opened it up to confirm this. So buy one with confidence, it is the BEST radio I have owned to date ,just push the scroll on the left side only and you will have no problems
fat500 is offline
Old 02-18-2009 | 01:29 PM
yeahm after mine broke the first time, I carefully and only clicked on the left side but it broke again anyways. Good advice, but not really a solution.
bennybtl is offline
Old 02-18-2009 | 01:32 PM
Careful man, if you talk bad about this radio you will get lynched. Your not allowed to say its defective, even though it clearly is.
Good luck!
trout74 is offline
Old 02-18-2009 | 01:54 PM
Clearly only being able to push one side of the button is a feature...
Linkdead is offline
Old 02-18-2009 | 03:22 PM
Ebola888's Avatar
Originally Posted by trout74
You not allowed say its defective, ...
One word, proofread.
Ebola888 is offline
Old 02-18-2009 | 06:04 PM
your a putz, I think I hear your mother calling. I dont have time to proof read my posts, im at work, im just checking in from time to time between clients, you have lots of time after school to make sure your posts are gramaticaly correct.
trout74 is offline
Old 02-19-2009 | 07:15 AM
racer1812's Avatar
Super Moderator
ROFL.......gotta go mom's callin'
racer1812 is offline
Old 02-19-2009 | 04:24 PM
fat500's Avatar
wow lots of Wisconsin boys here
I am from the dells / baraboo area myself so its all good, just suprising
Later fellow cheese heads
fat500 is offline
