Problem with EVX-2 ESC >
Old 02-08-2009 | 03:01 PM
Default Problem with EVX-2 ESC
Hey guys I have an older E-Maxx with the stock titan motors and I made 4500mah 6 cell tenergy batteries. I was using the original esc until it got wet and overheated the batteries. I then installed a new EVX-2 esc using a new set of the same batteries but now the truck seems much slower. I know the EVX-2 is designed for the newer e-maxx and the E-Revo with higher voltage. Could this esc not be compatible with my truck??
Manny110 is offline
Old 02-08-2009 | 03:19 PM
whitrzac's Avatar
did you program it to your radio?? mabey its in traning mode...
theres a page that has how to program it, and one that has the profiles
http://www.traxxas.com/PDF-Library/5605_manual.pdf
whitrzac is offline
Old 02-08-2009 | 06:26 PM
Try a diff set of batts - I've had some tenergys and they are poor. Since you've just made these pacs, test them on another Emaxx or use a diff set of batts in this Emaxx.
My tenergy 7 cell pacs were nearly worthless and were a waste of money.
Duster_360 is offline
Old 02-09-2009 | 06:06 PM
I will try to program the radio. Thanks for that tip. As far as the batteries they all came from the same batch and so far I have been happy with them. I used a bunch to re-build my dewalt battery packs also. I will try swapping the batteries if after I program the radio I still have issues. Thanks!!
Manny110 is offline
Old 02-12-2009 | 11:33 AM
Well I have to thank you for the advise!!!! I programed the ESC as per instructions and WOW what a difference!!! The truck rips wheelies while rolling on the pavement and on wet grass!!! As far as the TEnergy batteries I know I am new to the hobby but for the price of these batteries I have no complaints!! THANKS GUYS!!
Manny110 is offline
