Thats how bored i am, take a look...
...i am so bored that i sit here for hours trying to figure out, which way to put my new radio. ha ha...
seriously, i gave it some thought and i am not sure what the best position for it is...
position 1: as you open the case, it sits upright. that way though, the top of the radio is facing down when storing and transporting...
position 2: as you open the case, it sits upside down. that way it sits right side up when transporting and storing...
position 3: as you open the case, it sits sideways...that way you are kinda in between...
what do you guys think?
thanks
G
thanks
G
I say upside down. But then, i'm in the southern hemisphere, so that would be your right side up.
If you want to have it sideways, I think you need to take into consideration the additional drag you may encounter, which will affect the way you can carry it.
By the way, can I smoke what you're smoking?
you should NEVER run a nitro motor without the proper ventalation, exspecaly when you have accses to a computer.
Suspended
If you can sit there for hours... you're not bored, you've got Attention Deficit Disorder.
+1 for sideways
thanks
G
thanks
G
That just sounds so WRONG!
I think you should put it in diagonally. Screw convention be grand!
I reckon you've gotta think outside the box!!!!!!!!!
how aboud suspended in mid air by cables or better still have it in a 3 axis gyrating thingy, then it won't have a set possition.
